Page 148 of 390 FirstFirst ... 4898138144145146147148149150151152158198248 ... LastLast
Results 1,471 to 1,480 of 3899
    Dec 2009
    #1471
    Doc, is it Ok to use mobil delvac mx 15w40 on a gas engine?
    Dec 2007
    #1472
    Yes it's perfect for any gas engine, It has less than 1200ppm zinc in it so catalytic converter safe.
    Jan 2011
    #1473
    Sir am I right to say that markings on the 2 filters are different in orientation? Do you have a 360 degree view?
    *Ry_Tower, the marking is the same for both. The marking orientation direction is going to the thread on one side and going to the top on the other side. Noticed also the numeric markings at the bottom, just not sure what these stands for. There is also a COO on the main 12-pc box, it came from France...
    Dec 2007
    #1474
    If you go to the cummins site you can view the filter 360, Some of their filters now have the Fleetguard on both sides on is reverse.
    #1475
    Quote Originally Posted by tuazon7 View Post
    Thanks sir tuazon7 & dvldoc.
    Oct 2004
    #1476
    The locally available LF3564 filter has 2 marking orientations, 1 in front & the other at the back (shown by Tuazon07). It's what I am currently using together with FF5160, which also has 2 marking orientations.
    Dec 2009
    #1477
    i already removed my catalytic converter so i can use all the Zinc there is..haha... another thing DOc, im currently using fully synthetic 5w40, if i use the delvac 15w40 will there be any significant change in fuel consumption? or too little to notice?
    Dec 2007
    #1478
    Quote Originally Posted by miko101130 View Post
    Higher ZDDP will give you better fuel economy, but 40 weight oil is 40 weight oil, it's not going to make any measurable difference in 5w40 and 15w40. Whoever got the much ZDDP and moly will have the best fuel economy between the two.
    If you have no cat would be looking at just about any heavy duty diesel oil, Like ZIC, Delo, or Top1 all will last a very long time in a gas engine.
    Dec 2009
    #1479
    Monarc in Libis (sole cummins engine distributor in the Philippines) is conducting Oil analysis (complete elemental/wear/VI/TBN analysis) i called them up and their oil analysis cost 1,024.80 pesos... cheaper than others... their also conducting Virgin oil anaylsis
    Address:
    150 E. Rodriguez Jr. Ave., Libis,
    Quezon City, Metro Manila
    Tel: 635-0901
    im planning to have my used oil analyzed.. haha..
    Dec 2009
    #1480
    now we'll know which of the oils are really performer rather than marketing B.S... we'll know whats in their oils...
Remote bypass oil filtration
