Page 140 of 390 FirstFirst ... 4090130136137138139140141142143144150190240 ... LastLast
Results 1,391 to 1,400 of 3899
    #1391
    Nice, maluwang pa!
    yes, maluwag pa for the gas innova, however, like miko said, will also double check if the base is hitting something or not. hehe if not, then this is definitely a good upgrade. bigger filter and better filtration media.
    #1392
    If you have taken a picture of the base sakto sana since if flat no problem na nga. Hope it works excellent for you.
    *LR: Kasya atasa engine bay ng 4m40 and LF3918. Halos 1 inch addt'l length niyan diba? How much mo ba makukuha? Naghahanap na rin ako ng ipapa-ship eh. hehe
    Baka mas mura yung sa'yp. So far yung sa site na binigay ni dvldoc yung pinakamura eh.
    http://tsikot.com/forums/engine-fuel...9/index14.html
    #1393
    RT, wasnt able to take a picture of the base anymore since the time i realized that it was different from the one posted, it was already installed. this was yesterday afternoon. used it for 50kms last night. i took the picture of the filter lunch time today. and seems like theres no leak naman based on the photos. the filter itself still looks clean. kasi if may leak, tutulo na dapat sa side since the filter is upside down.
    Jun 2004
    #1394
    Quote Originally Posted by crazy_boy
    yep, they ran out already as of yesterday. as per the salesman, shipment has already arrived pending release from customs. he also said people from tsikot started hoarding daw haha!
    OT: paj4x4, can you suggest a good brand of crocodile jack? i remember reading before you were also looking for 1. thanks
    Thanks. OT - i got a 4 ton crocodile jack - Pali is the brand. Bought it from the store right after Volmax. Also got 6 ton jack stands from the same store.
    #1395
    RT, wasnt able to take a picture of the base anymore since it was installed yesterday. then used it for 50km last night, and took the picture lunch time today. as per my observation, no leaks naman since the side of the filter in the picture is still very clean. if theres a leak, dapat may oil marks na sa side since the filter is upside down position. hehe
    Quote Originally Posted by paj4x4 View Post
    Bentley sir? do you remember how much? because the cheap ones being sold in blade/ace are not that good in quality.
    Regarding Zic A 10w40 oil, after using it for 50km, im contented with it. car is running really smooth.
    #1396
    Jan 2003
    #1397
    hi doc! regarding the microglass media...I think I can source out an authentic LF3918 that can fit the 4m41....Im using Mobil 1 TDT....does that mean I can extend it also til 20,000kms? does all microglass media filters perform at par with each other? or it still depends on the part no.?
    Please let me know where your source is so I can get one for my 4m41 too ...Saw some Fleetguard oil filters being sold by Denso here in Baguio but for big trucks only and no filter that will match my stock filter. I think their stock are original since the filters have country of origin (made in USA) and are fully wrapped in plastic.
    Doc Dvldoc, I have been using Mobil 1 Delvac 5w40 for my 4M41 Strada and 2007 Kia Sorento. Expensive oil here in Baguio, sells for 800/liter at Ace Hardware SM. Ace Hardware also sells Valvoline oils and after seeing this link (http://www.animegame.com/cars/Oil%20Tests.pdf) you posted several pages back, I am thinking of trying the Valvoline Premium Blue 15W/40 which is almost half the price of the Mobil 1 on my next oil change. What's your take on this, Doc? Should I stick to Mobil 1 Delvac fully synthetic or is it okay to shift to the cheaper Valvoline semi-synthetic oil? Oil change is 10,000 kilometers interval on both my Sorento and Strada.
    #1398
    Quote Originally Posted by G01 View Post
    P800, parang motul na yan ah.. I suggest sir kung magawi ka sa Cash and Carry P440 lang ang Mobil1 TDT..
    Dec 2007
    #1399
    The only problem with the LF3918 is it's pretty dang long
    Largest OD 92.96 mm (3.66 in)
    Overall Height 175.77 mm (6.92 in)
    Thread Size M26 X 1.5
    But yes all the microglass preforms about about the same. 98% * 20 microns and 50% * 7 microns.
    The none microglass version is the LF3746
    Baldwin makes a dual flow version of that filter that is similar to the BD7317 I posted earlier and is a 50% at 5 microns
    BD7095
    Thread: M26 x 1.5
    O.D.: 3 11/16 (93.7)
    Length: 7 1/8 (181.0)
    This could be a great find for if it will fit. These are double the size of your normal OEM filter, the Baldwin is a true bypass filter as well and would give you around 8000klm over the fleetguard. It also has a microglass media.
    Guess it would boil down to price and availability.
    Dec 2007
    #1400
    The mobil 1 performed poorly in that test due to it's API SM API rating
    Vavoline Blue has a TBN of 13.5 it's for commercial truck use, it's fleet oil designed for extended oil changes.
    Phosphorus 1197ppm
    Zinc 1395ppm
    Molybdenum 88ppm
    Boron 142ppm
    Sodium 2ppm
    Calcium 3076ppm
    Magnesium 10ppm
    Strong Anti-friction and cleaning package.
    Compare with Delvac 1 which is OK oil, the Calcium level is way way to low to use one diesels in the Philippines, Fine for gas engine but your going to get a sludge monster using 1/4 the calcium as normal diesel oils.
    TBN is only 10
Remote bypass oil filtration
