Results 1,021 to 1,030 of 3899
Tsikot Member Rank 1
- Jul 2009
- 4,090
January 25th, 2012 05:37 PM #1021Just got my mobil 1 turbo diesel truck, now 450 *trading post , 2nd floor of cash and carry
- Jun 2005
- 3,774
January 25th, 2012 08:54 PM #1023hey doc, do you know the technical specs of mobil1000? it readily available is it a good dino juice?
- Jul 2009
- 4,090
January 25th, 2012 11:36 PM #1024
January 26th, 2012 12:32 AM #1025
It's no better and no worse than a oil of the same API rating that is group II oil.
Mobil Super 1000
Here is a good listing I found which breaks down oils brands with what group of oil they are ie. Group II, III, IV or V.
Auto-Rx (Philippines) | About Oil
January 26th, 2012 12:35 AM #1026
It's no better and no worse than a Group II oil with the same API rating. Not a big fan of Group II as it has a lower TBN and will have to be replaced sooner. You would be better off with a group III oil.
Here's a good listing of some oils there with the groups types.
January 26th, 2012 10:53 AM #1027
Mobil 1 15W-50 Advanced Full Synthetic Motor Oil
API rated only as CF plus its rated SN which is not ideal for diesel per se, maybe better off using Mobil Delvac MX 15w40 or Mobil Delvac 1 5w40 instead if meron sila sa Trading post.
MOBIL DELVAC 1 5W-40
Viscosity, ASTM D 445
cSt * 40șC 102
cSt * 100șC 14.8
Viscosity Index, ASTM D 2270 151
Sulfated Ash, wt%, ASTM D 874 1.35
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, șC, ASTM D 97 -45
Flash Point, șC, ASTM D 92 226
Density * 15șC kg/l, ASTM D 4052 0.854
Moreso from 2 threads i've read they stopped making this already.
mobil 1 synthetic 15w 50 silver cap auto oil - Bob Is The Oil GuyFasten your seatbelt! Or else...Driven To Thrill!
January 26th, 2012 02:04 PM #1028
^in contrary, API CF is rated for use with diesel fuels having greater than 0.5% ppm sulfur. higher than CF are those oils for use with fuels lesser than 0.5% ppm sulfur. not that i'm against those high ratings with regards to API ratings (actually, i've been a user of CI-4 delo gold multigrade). what i'm saying is if you use API rated oils higher than CF, you have to change your oil more often than when you are using CF. by the way, i dropped my pan for the first time and i'm really surprised with the internal condition. no sticky gunk on the pan as well as on the sides of the block. well, thanks to delo of course. found only bits of silicone sealant at the pump screen and on the pan as well. i filled her up again with valvoline CF-4 15w-40.
- Jul 2009
- 4,090
January 26th, 2012 02:45 PM #1029
- Jun 2009
- 43
January 26th, 2012 04:40 PM #1030
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
