Results 11 to 17 of 17
December 21st, 2002 02:33 PM #11
boybitz,
thanks a lot for the infoyour efforts are highly appreciated
sa honda kase I was checking out the superhonda forum and it says there that in honda trannys you could either use Honda MTF or Redline MTL/ MT 90. basta GL 4 yung rating ng Transmission oil.
I'm not sure about Lancers though :oops:
- 370
December 23rd, 2002 09:09 AM #12I used to use MT90 but drained it, because it shift action seemed stiffer.
Now I'm using 40 weight motor oil with MoS2 additive for it.
December 23rd, 2002 03:12 PM #13
for yourr info lang......GL 4 rating ba kamo...isa sa gear oil ng Caltex is MTO Thuban GL 4 SAE 90
pero I'm using Havoline Formula SAE 20W-50 as my gear oil kasi eto nakalagay sa Caltex Auto Lubrication Guide for M/T ng Honda Civic and Accord from '98 to '01...
- Nov 2002
- 162
December 24th, 2002 12:27 PM #14bossing chief,
how bout for 99 lancer? ano pong nakasulat na pwedeng gamitin?
- 67
December 28th, 2002 02:44 PM #15my previous civic logged in 120K++kms and it used 20W50 motor oil for its transmission. never had any problems so i guess its safe to use them.
- Nov 2002
- 162
January 2nd, 2003 09:24 AM #16logic says... if you use motor oil for your transmission fluid and you're supposed to use transmission fluid for your power steering (tama ba?) then can you use motor oil for your power steering?
- Nov 2002
- 162
January 4th, 2003 02:48 PM #17post ko lang, I called up Superior Motors kanina, they are transferring to another office na daw, sa may likod na daw ng Pegasus. Their number there is 3725093. Baka by next week daw lilipat na sila dun.
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
