Results 1 to 10 of 23
May 13th, 2005 05:18 PM #1
pardon me if there is a similar thread discussing this...
I installed a gas saving device (it comes in a chrome cylindrical casing) that supposedly will make my truck ('99 4WD Frontier) more efficient (more kms/liter, increase in power, less emissions, etc.) and so far, it seems to be working...
I've been browsing through several threads about Khaos and its effects on the engine and since the device I have (I think its called GASSAVES) supposedly works the same way does it follow that it will have the same effect on my engine?
May mga gumagamit ba sa inyo ng device na 'to? Kamusta naman epekto sa mga sasakyan nyo?
May 13th, 2005 05:21 PM #2
I know a couple of people (one is a fellow tsikoteer) who installed Khaos in their vehicles, minimal or no gains whatsoever, they removed and sold it.
May 13th, 2005 05:40 PM #3
If it works the same way as Khaos, it'll have the same effect on your engine.
- May 2005
- 26
May 13th, 2005 11:43 PM #4ako gas saver gamit ko din. :D masmura sya versus the khaos :d i felt na mastipid nga yng fuel consumption and knowing that NOx would be the effect after the day we installed it :p anyways, mas meron laman (content) naman ang gas saver compare sa khaos which is purely restricted air. but then again i may be wrong...
anyways, ang mileage ko went from 5-6 m/lkiter to 6-7 km/lkiter.. so ok naman :d
- Mar 2007
- 12
April 25th, 2007 07:06 PM #5Hi! Has anyone here tired this relatively new electronic gas-saving device branded as AERONOX? I find it way too expensive. I'm just wondering if anybody here na nakabili at nakasubok na nito at sulit na naman or just another snake gadget out there to get millions form kawawang cowboys. Salamat.
April 25th, 2007 07:41 PM #6
April 25th, 2007 09:07 PM #7
Here's my take on fuel saving devices:
"I believe that the engineers working at automotive manufacturing firms spent time in school, graduate studies and intensive (not to mention, expensive) research. So, THEY would engineer the engines that they design and make to perform at at its best. Fuel efficiency and power (torque) are taken in as primary factors in the design of the engine. THEREFORE, no fuel-saving device actually work on any of the modern engines that we have because they are now performing at optimal levels."
Check these threads:
http://tsikot.yehey.com/forums/showthread.php?t=36167
http://tsikot.yehey.com/forums/showthread.php?t=15780
Do you really want to save gas? Check these out:
http://tsikot.yehey.com/forums/showthread.php?t=33194
http://fuelsaving.info/
my two cents po
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 26th, 2007 08:59 AM #9
April 26th, 2007 09:13 AM #10
IMO. Considering na effective nga. It’s just very minimal. How about the
risk factor na pwedeng idulot sa makina. Ilang libo ang halaga n’yan? na
ang benepisyong kapalit ay baryang katipiran sa krudo.
VinFast VF 3
