Results 1 to 13 of 13
    Jan 2003
    hello car gurus! the timing belt and tensioner bearing of my vti civic (phdm) is due for replacement. can you recommend a good replacement parts brand which won't hurt my pocket?TIA.
    sa mga vital parts like timing belt go sa original
    try mo call ang hond amagallanes 9029393
    si PINOYK20 09273830646 pwede text
    or si BANAWE 7120155 regy
    Jan 2003
    Quote Originally Posted by raine View Post
    im asking for good replacement part for obvious reasons. thanks anyway!
    Quote Originally Posted by conzky View Post
    i'm sure bando has one for tb's. para sa tensioner, di ko alam.
    kaya ng binigay ko number compare mo ang price baka di naman gaanoon ang diperensiya. at yung isang number ni banawe makakakuha ka na rin sa kanya ng replacement kung replacement ang gusto mo, tawagan mo lang, tapos
    Oct 2009
    Honda Car does not make their own timing belt nor its tensioner bearing. They let other manufactures do their parts with their specs.
    Try other brands, such as Gates, Bando, Sun for timing belts and Koyo, NTN, NSK, GMB for its tensioner. In my experience as a mechanic, i have never seen a mechanical damaged when a timing belt breaks in a honda VTEC engine. You can also use lesser known brands but please to derate them (i.e. instead of 100K kilometers, replace them 80K)
    Jan 2003
    sir, in the first place, you were not answering my query. in the second place i'm from the province. PROMDI AKO! that's the reason why i'm asking here for help. i hope this will clarify.
    Jan 2003
    Quote Originally Posted by paulgozon View Post
    Yes, there are OEM and replacement brands and i know that OEM are quite expensive so im opting for replacement brands. Thanks for the infor sir:
    For the belt, I use GATES. Not sure about the tensioner but stick with known brands like NSK, etc. These brands also manufacture parts for heavy equipment subjected to more stress than you Honda will ever go through in its lifetime.
    Jan 2003
    Thank you sir for the recommendation. i appreciate it very much.
    i dunno if this is late na.. but anyway, GMB ang ipinalit sa water pump & tensioner ko. belt is Honda OEM. works & parts c/o speedyfix. btw, same po '97 VTEC VTi din po sa akin.
    thanks guys! this is really very helpful. i might go to speedyfix din next week to have my timing belt replaced - it's a honda city type z '02 model.
    where would u recommend i buy the timing belt (orig), water pump and tensioner parts? bka kc fake mabili ko, i was considering sa shop na din bumili but i'm not sure kung malaki ba matitipid ko kung bibili sa labas.
    thanks!
    Quote Originally Posted by aldz1482 View Post
    thanks!
    'though pede na lahat kay sir migs (speedyfix) para less hassle. Honda OEM belt, GMB water pump & tensioner. or you can buy din sa labas, sa belt paps, sa Honda ka na mismo bumili, Honda Shaw malapit dyan sa speedyfix other parts sa mga trusted auto supply. try here sir, quoting from post ni sir apecsos:
    Quote Originally Posted by apecsos View Post
    In summary, before you proceed in having your car fixed in Rapide....canvas the parts first in the following:
    1) Mitsubishi ---- Atco Auto Supply
    2) Honda ------- Partstar Auto Supply
    3) Toyota ------ Celica Motor Sales/Aerodynamic Auto/NGK motor Sales---1 owner
    4) Hyundai/kia and other korean vehicles ---- Fronte Auto Supply
    5) GM and other American Branded Vehicles--- Thunder Automotive
    6) Ford/Mazda - Fordline / Bestford Auto
    7) Isuzu - Jayson Auto Supply
    8) Assorted Replacement parts/ Kayaba Shocks/engine supports/shock mountings/ overhauling parts etc etc - Chuan Lam Auto Supply.
    9) Bearings - Japan Parts/ United Bearing
    All of these places are direct importers and undoubtedly the cheapest when it comes to parts
