hello car gurus! the timing belt and tensioner bearing of my vti civic (phdm) is due for replacement. can you recommend a good replacement parts brand which won't hurt my pocket?TIA.
sa mga vital parts like timing belt go sa original
try mo call ang hond amagallanes 9029393
si PINOYK20 09273830646 pwede text
or si BANAWE 7120155 regy
Honda Car does not make their own timing belt nor its tensioner bearing. They let other manufactures do their parts with their specs.
Try other brands, such as Gates, Bando, Sun for timing belts and Koyo, NTN, NSK, GMB for its tensioner. In my experience as a mechanic, i have never seen a mechanical damaged when a timing belt breaks in a honda VTEC engine. You can also use lesser known brands but please to derate them (i.e. instead of 100K kilometers, replace them 80K)
For the belt, I use GATES. Not sure about the tensioner but stick with known brands like NSK, etc. These brands also manufacture parts for heavy equipment subjected to more stress than you Honda will ever go through in its lifetime.
