Results 1 to 9 of 9
January 31st, 2006 11:29 PM #1
i tried this oil, cost was only 68 pesos per liter, but the spec was misspelled.. it read DEXON type 2, kulang ng R anyway i tried it on my gen 2 pajero.. and it worked well! pick up and shifting improved a lot...
but still i wonder about this oil, has anyone used this???
February 1st, 2006 12:36 PM #2
May DEXON ata talaga, Shell AFAIK is DEXON... Pero mura naman sobra? Average price ng DEXON is 130-150/li...
February 1st, 2006 09:25 PM #4
yes mura nga!.. afaik DONAX ang shell, made a mistake in using this last time i chabged my tranny's oil... panget response! magaspang shifting.
anyway dexron 2 lang naman daw recommended sa 2.5tdic pajero, so i don't see any reason aside from unavailability to use dexron 3 instead.. besides, its hell of a lot cheaper! kahit isabay ko palagi ang atf change oil sa engine change oil
btw, i went to laguna earlier this day, despite the hot weather, cruising 120 kph, mix city and highway driving, the A/T feels good, seems to shift smoother than before.
February 2nd, 2006 01:03 PM #5
Sorry tama ka DONAX ang Shell...
Sobrang mura nyan, sana yan kinuha ko hehe just changed my ATF using Caltex, smooth as silk ngayon din shifting.
Ilang liters nagamit mo.
February 3rd, 2006 01:42 PM #6
4 liters lang na consume e... drained the oil pan, then replenished.. tapos tinangal ko yung isang hose sa oil cooler and let it idle.. until nag clear yung atf na tumatapon. turned off the engine then replenished..
kung magtatagal na ganito kamura yung atf na to, kahit mag change atf oil ako every 10k kms
February 3rd, 2006 02:00 PM #7
ako din eh, hehe when i had my atf changed yesterday, i figured, mas mura pa to sa change oil sa makina, might as well do it yearly since mga 5K/year lang naman byahe ko sa oto hehe.
February 12th, 2006 12:29 PM #8
v22, san ka nakabili, i'm planning to replace nga din may atf fluid this month, been gone to different shops looking for a goop but reasonable price brand. I've been using whiz atf dexron 3 for only 110.00, i'm looking for a more better product, pero kung may ganyan kamura and just like what you've said ok ang response might as well try it.
February 12th, 2006 06:26 PM #9
just bought it from a nearby auto supply here in tondo.. try mo yung mga auto supply na may truck parts...
high idle RPM at engine start
