i tried this oil, cost was only 68 pesos per liter, but the spec was misspelled.. it read DEXON type 2, kulang ng R anyway i tried it on my gen 2 pajero.. and it worked well! pick up and shifting improved a lot...
but still i wonder about this oil, has anyone used this???
yes mura nga!.. afaik DONAX ang shell, made a mistake in using this last time i chabged my tranny's oil... panget response! magaspang shifting.
anyway dexron 2 lang naman daw recommended sa 2.5tdic pajero, so i don't see any reason aside from unavailability to use dexron 3 instead.. besides, its hell of a lot cheaper! kahit isabay ko palagi ang atf change oil sa engine change oil
btw, i went to laguna earlier this day, despite the hot weather, cruising 120 kph, mix city and highway driving, the A/T feels good, seems to shift smoother than before.
4 liters lang na consume e... drained the oil pan, then replenished.. tapos tinangal ko yung isang hose sa oil cooler and let it idle.. until nag clear yung atf na tumatapon. turned off the engine then replenished..
kung magtatagal na ganito kamura yung atf na to, kahit mag change atf oil ako every 10k kms
ako din eh, hehe when i had my atf changed yesterday, i figured, mas mura pa to sa change oil sa makina, might as well do it yearly since mga 5K/year lang naman byahe ko sa oto hehe.
v22, san ka nakabili, i'm planning to replace nga din may atf fluid this month, been gone to different shops looking for a goop but reasonable price brand. I've been using whiz atf dexron 3 for only 110.00, i'm looking for a more better product, pero kung may ganyan kamura and just like what you've said ok ang response might as well try it.
