Hi All!
Here's my take on this:
Just follow the specs in your manual and you should be OK.
I'm currently using Rimula X in my rig and it's running great!
While I would like to try Helix Diesel, my finances are a bit restrictive at the moment
As for start ups, I just do what my manual says. Let my engine run for about 10 seconds, then it's good to go.
But of course, you have to drive gently until it gets to normal operating temps before actually pushing it.
Following your maintenance schedule is also a good idea.
While going all out in terms of cost for your rig is not bad if you can afford it, NEVER, EVER, skimp on the parts and consumables that you will use on your rig.
It'll definitely bite you in the *$$ someday. Most likely sooner than later.
Hope this helps.
:regards:
