I'm planning to get started with my filters. kaso, I'm deciding whether to go for the open type or not...If I go for the open type, will it compromise my water fording capability? I know its somewhat silly to ask but then will water get into it?
check the AEM website, they have a bypass valve thingy if u happen to suck water w/ the open type filter, for me mas gusto ko drop-in filter para mukhang stock
Originally Posted by notEworthy27
In my opinion, unless you are racing the car at wide open throttle and hit a water puddle, there's little chance for the engine to take in water. As long as the filter is above water level, you should be ok. The surface area of the filter is big enough to keep it from ingesting splashed up water.
the bypass valve is only practical for cars equipped with cold air intakes, since the filter is located very close to the bottom of the car and is vulnerable being splashed or even submerged in water.Originally Posted by trup
go for an open-type filter to get the most out of it.
so if i wanted to improve my air intake go for the open type? it would be more efficient as compared to the closed types? lets say I go through a flood, a tire high flood. will the intake be more efficient if it were an open type? or since a closed air filter's opening is located at the bottom, it would more likely ingest water?
An open type filter will usually be more effective as an air source over a filter in an airbox.
There are exceptions in systems where the airbox & air tract is part of or taken account into by the ecu programmer/engine designer.
If you plan to fjord water then the best place to get your air is above or roofline level, assuming you've waterproofed your engine that is.
Most stock configurations use an airbox for 1) to minimize air intake noise, and 2) to afford a certain degree water ingestion protection. I would say the chances of the engine taking in water is just about the same for a boxed and an exposed (open) filter.
Like I said earlier, unless the engine is running at a very high rpm and the throttle valve is wide open, splashed up water usually doesnt find its way into the intake air duct. The reason behind this is because water is heavier than air, and if the engine vacuum had the choice, it would draw in the air far more easier than it would draw in water. Up until available vacuum (like when under the given set of conditions above) exceeds the available air to be drawn in, will the engine start to take in the water, too.
Boxed filters usually have 2 intakes, 1 facing the bottom to drain any water finding its way in the air duct, and the other facing forward and away from the engine for a cooler intake air. Other designs also use a 3rd intake taking air in from some kind of heat exchanger in the exhaust manifold through a flap controlled by a thermal spring that diverts air between the 2 intakes.
I forgot to say this in my previous posts. my ride is a strada TDIC. where's the air duct for the intake directed to? :D
Why are you asking me this? Why don't you find it out yourself? You have the car at your disposal, dont you?
I had a '97 Strada before, and had open-type cone K&N Filter installed. Prices (a few years ago) were about P4,500 for the filter, and about P2-3k for the installation (kasi they had to fabricate brackets and stuff).
Best money I spent for my Strada. Well, second best; the best pala was changing shocks (I had Old Man Emu) -- MUCH better ride.
PROs: Better fuel efficiency, UNLESS you get gigil because of the BETTER acceleration. If you don't change your driving habits (tempting kasi with that mod), you'll save fuel and get better acceleration.
CONs: Medyo mas umingay yung Strada, and when you accelerate, you can hear a sucking sound ("humihigop ng hangin" sound).
Notes:
1. Keep the stock air box somewhere safe after. I re-installed stock air box when it was time to sell the Strada.
2. Unless you go to really deep floods, water won't get in. In fact, in my estimation, a STOCK strada and my K&N equipped strada could ford the same depths.
3. You will lose the option of installing a snorkel.
EDIT:
1. Kung K&N na filter lang ang kukunin mo (not the open type), the difference, I think, will be minimal. The restriction, apart from the filter element itself, was (at least in a 97 Strada) was the air box/intake itself.
2. The "humihigop ng hangin" sound is very slight... until the turbo kicks in. Then it sound like you're, um, hmmm... try this: make a face like you're whistling... now instead of whistling, suck in air fast... there... that's the sound.
From one (former) Strada owner to another, I'd say you should hie thee to Fusion Motorsports and have Auto_Xer install one for you.
BTW, for open-type installations, I trust ONLY Auto_Xer to do that for me (bracketing and such). FYI, I used to live in Alabang, and the trip to QC (at that time, Auto_Xer was in the Banawe area) was worth it. Installation took about 2-3 hours.
strada..... there was once a box type strada that entered here in an off-road competion for stock 4wd's, the first obstacle was water fording about half tire deep. when he entered it was ok but after the water obstacle the stradas' exhaust pipe was smoking white smoke and was palyado, after a few meters the engine died. so it was towed in the side while the other stock 4wd's continued the race. since it was my friends car we chck out what happened. when we opened the air filter assembly it was drenched with water there was a hole for drainage but the water was too much for it. so we dried up the filter in the air and tried again to start the engine, good thing that the engine started but was palyado at first then after a while ok na. he sold it btw after a year. the other stock vehicles has no problem with the water obstacle, im not saying that the strada is inferior, and i mentioned stock because all had close air filter boxes no open type. i just want to point it out that even with the stock closed air filter housing there is a danger of water ingestion how much more for open type filters. we were wondering why so much water went in then we saw that the opening or inlet of the air filter housing was facing the radiator fan, i dont know if its the same config with the TDIC. if i were you drop in ka na lang to be safe or snorkel if you want more air.
Why not change to performance drop-in filter then install a snorkel afterwards?
ano pong ibig sabihin ng "drop in" filter? sensya na di ko alam terms, does it mean yung standard type? meaning paper type?
yes drop-in usually refers filters that replace the OEM but of different brand, like Finer Filter, K&N, and other replacements.
i installed HKS drop in filter in our gen1 n gen2 crv n cefiro, HKS is ok! gen2 crv filter is huge btw!
i read in arb safari website that their snorkels does ot recommend those oiled-foam type of filters.
parang labo nga kasi, parang ala namang point, anu yun baka kasi madaling matuyo kasi open na?? pwede b yun? hehe, pwede din cguro =)
I had Finer Filter installed in my strada before the K&N. The Finer Filter was a stock replacement (still used the air box). The K&N, I chose the open type. It's apples to oranges, but sobrang layo ng difference with the Open Type K&N. I wish I never spent money on the Finer Filter.
I'm not saying the Finer Filter is junk -- it's just that K&N is so much better. imHo.
The stock Mitsubishi 4d56 has built-in safeguards for water and dust ingestion. It sucks air from beside the headlamp (ala cold air intake) but instead of going directly into the air filter, it will first pass through the hollow area of the right fender. This is so that any dust or water will be dumped into the inner fender instead of straight into the air box.
The airbox itself is equipped with a cyclone system (ever wonder bakit parang elesi ang air filter ng 4d56?) which makes dust settle into the built-in dust pan in front of the filter housing. At the bottom of the dust pan is a rubber valve that opens should water get in or should there be too much dust build up (e.g. you don't clean your dust pan regularly).
I'm not really a fan of open type intakes on 4d56 engines.
i agree alfa, im using a finer filter, but i think K&N is better, but more expensive too. What i like bout the finer is they use like a special oil, u know, and maybe this traps in more dirt too.
but, if you make the filter type open, how about it being exposed to the heat of the engine? do you think those covers i see in the magazines help?
