I used to work as a lab analyst in a power plant in Navotas, I check the oils upon delivery, I know a little about engine oils but I'm no expert, Iba kasi additives ng engine oil for diesel engine kesa sa gasoline engines, mas mataas ang TBN ( total base number) ng oil for diesels para makontra yung acidity ng diesel, if you will use a purely gasoline engine oil prone sa corrosion ang internals ng engine mo
