Results 1 to 20 of 27
    Quote Originally Posted by duncan_sheek View Post
    yep, thats right. I had it checked right away. yun palang isang hose loose na or medyo nahuhugot ng konti(di ko alam tawag sa hose). kinabit ulit ng mabuti ng mekaniko and had it clamped. While at it, pina-check ko na din buong fuel lines and everything seemed to be fine. Peace of mind now... Thanks!
    fuel return line
    Jul 2005
    up ko lang ulit. upon checking my gas tank again, nakita ko sa ilalim basa ulit. I traced the source, it seems to be coming from the tank itself. meron maliit na singaw. Can a patch remedy this? ok ba yung epoxy steel or anyone can recommend a patch for this. Meron akong napanood na tv commercial, yung radiator patch(don't know the brand name) parang ok din yun. Thanks in advance.
    duncan,
    it's quite a hazard to drive your car with the fuel tank leak...a small spark nearby can blow your tank (seriously!) remember that fuel is highly combustible. i suggest you correct the problem by having the tank welded (oxy acetylene ang katapat nyan) needless to say, that the tank should be airdried / emptied for a couple of weeks before servicing it...i won't risk patching it with a steel epoxy...
    Jul 2006
    And when you do have it welded, make sure it is EMPTY and DRY!
    You don't want to run the risk of catching a spark like Mangdencio said. Better yet if it's a rubber line that leaks, replace it na lang with a new one rather than remedy it. If it's the tank itself that's the problem, have it patched properly to ensure rust will not appear and the fuel will not seek another weak spot.
    It would be good to also indicate the car you have.
    Jul 2005
    Thanks, mbeige and mangdencio.
    Thats right, it should be welded properly and have it airdried first... well, I temporarily placed an epoxy steel patch while I look for a shop who can do that kind of service in mandaluyong. Drain the tank, remove and wash it by water, airdry and weld. Hassle pa no? what if I buy a new fuel tank para install nalang. By the way, car is corolla 90 GL.
    Jun 2006
    Yes, just get a new tank. Even if you repair the current leak now, somewhere, another one will turn up soon.
    Nov 2003
    if the leak is comming from the hose then just have that replaced. if the tank itself is cracked then better nga to replace it.
possible fuel tank leak
