Results 1 to 20 of 27
    the claims are ridiculous
    Feb 2014
    doesn't cure cancer? nor raise the dead
    i'm kinda disappointed
    it won't cure wood rot?
    high....
    Apr 2012
    ultra amazing! maybe it's the solution instead of LTFRB phasing out all the aging jeeps in the Phils
    Jun 2008
    Is this engine oil? If so why it says outstanding result when used in transmission, power steering, differentials, etc. Hmmmm.. Something not right. Power steering use hydraulic fluid not engine oil.
    Sent from my NX549J using Tsikot Forums mobile app
    Snake oil.
    Sent from my SM-T705 using Tsikot Forums mobile app
    May 2015
    Hi,
    Have any one here tried Polytron Brand? We're you able to compare and see if claims are valid? Hope you can share your personal experience.
    We do learn alot from tsikot members by reading informative posts and comments. I hope before posting anything about any product, you could have at least tried or used it. Thank you and God Bless.
    Sent from my SM-N950F using Tsikot Forums mobile app
    Apr 2012
    Quote Originally Posted by nyelly01 View Post
    Hi,
    No thanks
    The ad print itself is BS already. No need to try
    Sent from my SM-J730G using Tapatalk
    May 2015
    No thanks
    How can you judge and put negative remarks in something you actually don't know? And bother even trying at least.
    Oh well this is a free world. Hope it doesn't happen to us and what we do. Whats goes around, comes around. That's all.
    Apr 2012
    We know that's BS. Too good to be true promises.
    Ilang dekada na lumipas, nakarating ang tao sa buwan. Sana wag maging mangmang[emoji16][emoji23]
    Sep 2018
    We TESTED this product on a 2.4V Honda Accord (2004) which is known to consume a lot of gas!
    We drive to Baguio every week and have this CONSTANT PROBLEM of overheating and decreased power thus our family turn off the Aircon when driving and still get some overheating periods along the way (so we have to stop once or twice) but when we used this.. (just in order to test it out), we drove again to Baguio all the way with our Aircon TURNED ON and there was NO OVERHEATING whatsoever and felt an increase in Engine power!!! **Nothing beats that!!!**
    Saw also the actual demonstration of the Polytron team coming from the USA with a Friction device and when Polytron was added Friction was lowered and made constant as compared when just using the BEST Engine Oil out there.. The levels didn't change though one put soil, rocks or water on the circling friction device.
    My credential? Am a registered *SCIENCE AND TECHNOLOGY SCIENTIST" by the Civil Service Commission and DON'T believe fantasy ideas easily without data and experimentation.
    **My take on this matter > Most cars nowadays are still new thus adding novel products like this may really not give the user that feeling of a boost BUT microscopically, your engine protects itself and will thank you in the long run. I encourage skeptical drivers to test it out yourself first before arriving into conclusions. Discuss with me for further inquiries and experimental data. Don't try it if you're suspicious of everything.
    Hi,
    if one carefully and critically reads the ad, one comes to the conclusion that it promises nothing more than what current oils are already doing.
    i mean, current oils do most of these claims, already. it is only our imagination and extrapolation, that makes it seem as if the product is much, much better than regular oils.
    note that the ad does not claim to function much better than current regular oils.
    the palusot here is, "...compared to what?". that ad does not say what. but we-the-reader, will reflexively fill in the blank with "current oils".
    May 2015
    Thank you and God Bless to all.
    Wala kasi miracle engine oil or additive sir. Kung totoo kasi claim niyan, mayaman na yan at na-feature na sa mga bigating magazines and scientific journals. Bibilhin na patent niyan for sure sa ganda ng performance.
    If its too good to be true, it often is.
    I have tried similar products like this who have even more ridiculous claims. (Duralube)
    Felt no changes on the car’s engine. Now here we are again with a same product.
    Sep 2012
    ahhh kaya naman pala... galing sa katas nyan kaya merong microscopic particles [emoji23][emoji23][emoji23]
Polytron Lubes Scam Alert
