Results 1 to 7 of 7
    Jun 2009
    Sir anu po ba ang dapat kong ipaayos kase ung sasakyan ko nageemit ng white smoke tapos pag nagrerev ako ng engine may tubig na lumalabas sa muffler..please help me..Thank you in advance.
    ;magkano po ang magagastos ko dito,kahit estimate lang po..thanks again.
    Apr 2004
    naku, mahal yan, baka mga 300,000. hehehe joke!
    ano itsura ng white smoke? para bang naghagis ka ng smoke grenade sa counterstrike:source, na halos wala na makita sa likod mo pag umaarangkada? or parang slight fog lang sa baguio pag labas sa tambutso halos nawawala din?
    if its the former, guide seals.
    if its the latter, maybe just morning condensation.
    try mo muna ipa-tune up and ayusin yung timing and tappet clearance adjustments. you can also have the throttle body cleaned. yung casa gumagawa nito, as with other tsikoteer suki shops (please do a search na lang i'm too lazy to post directions kasi marami sila).
    remember: sa pag maintain ng lumang kotse, unahin ang murang pagawa bago ang mahal. huwag magpapa-uto sa (at least, not yet) mga magsasabi ng top overhaul yan or baba na ang makina nyan.
    huwag pumnta sa mekaniko ng mga owner type jeep/tamaraw fx. hindi nila alam yang makina ng kotse mo.
    huwag magpagawa sa mga istambay na mekaniko sa banawe. lokohin ka nun.
    pumunta lamang sa specialistang shops na may tamang gamit na hindi nakalagay sa bag na maliit. minsan taga sa presyo but thats the price we all pay for driving modern cars.
    Jun 2009
    okei sir voltcastillo i'll do that...thank you so much!...
    other suggestions and solutions are welcome.thank you again.
    Tama si Volt. Normal lang white smoke pag malamig pa makina at tubig ( moisture ) lumalabas sa tambutso.
    May 2007
    Sometimes, in the morning especially if the weather where you live is very cold everyday, when the engine is still cold, it gives out white smoke with steam called codensation. As the engine heat up, it goes away. Try turning on your engine when its hot outside and see if it still do it.
    Could it be a blown head gasket also. White smoke is always caused when water get into a firing clyinder, only way this could happen is that compression blows a gasket out and water gets in. if it is, you have to replace the head gasket. Check if you loose amount of coolant.
    Jun 2009
    mga idol,
    khit uminit na din engine my white smoke pa din lumalabas,ano po kaya problem?
    regarding po sa water coming out of the muffler,di naman po nagbabawas sa water reservoir or sa radiator..
    pls. help mga sir..thank you ulit..
    May 2007
    Quote Originally Posted by streetsweep View Post
    mga idol,
    Only way to find out is have a compression test on your car. Im pretty much sure that the head gasket are ready to go. Its a small leaked, not yet full blown but the damage on gasket are in need an attention.
Pls. HELP Honda 97 PH16a
