okei sir voltcastillo i'll do that...thank you so much!...
other suggestions and solutions are welcome.thank you again.
Tama si Volt. Normal lang white smoke pag malamig pa makina at tubig ( moisture ) lumalabas sa tambutso.
Sometimes, in the morning especially if the weather where you live is very cold everyday, when the engine is still cold, it gives out white smoke with steam called codensation. As the engine heat up, it goes away. Try turning on your engine when its hot outside and see if it still do it.
Could it be a blown head gasket also. White smoke is always caused when water get into a firing clyinder, only way this could happen is that compression blows a gasket out and water gets in. if it is, you have to replace the head gasket. Check if you loose amount of coolant.
mga idol,
khit uminit na din engine my white smoke pa din lumalabas,ano po kaya problem?
regarding po sa water coming out of the muffler,di naman po nagbabawas sa water reservoir or sa radiator..
pls. help mga sir..thank you ulit..![]()
