Results 1 to 5 of 5
- May 2010
- 17
August 16th, 2010 12:54 AM #1Hi guys,
I am having problems with my Honda City 08. i noticed this about a month ago. My gas consumption is increasing. as of this moment, i am running at 6km/l. I had my oil and spark plug replaced. pero wala pa din. I don't know kung may tagas ba gas tank ko. or what. I need your advice before I bring this to the mechanic. Thanks!
August 16th, 2010 03:19 PM #2
Dear Sir:
There are many possible reasons why you ride is consuming more gas.
One is the lack of regular, COMPLETE maintenance.
To wit, did you replace the air and oil filter when you changed the spark plugs and oil?
Did you tune it up when you did so? (Check timing etc?)
Did you replace the muffler or pipes with larger ones?
Another reason could be the type of driving you're doing - are you stuck in traffic for hours and hours?
Give us more info and we will be able to give better advice.
Best Regards,
Dusky Lim
August 16th, 2010 04:44 PM #3
- Apr 2008
- 51
August 27th, 2010 07:32 PM #5assuming you already did all the regular maintenance required: change oil, spark plugs, clean/change air filter... if you can get access to an OBD scanner, you can check the LTFT (long term fuel trim) and STFT values of your car for any abnormally high readings. probably you have a "rich" condition. I've seen similar conditions without turning on the yellow check engine light for an error code. dirty/faulty MAF sensor and oxygen sensor can also cause this
medyo disappointing itong Sealion 5 No ADAS No 360 camera
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
