Results 31 to 40 of 50
Zombie
- Aug 2006
- 728
November 13th, 2006 12:13 PM #31hmmmm. dami mo gagawin after mag swap ng engine, kelangan mo ng stronger chassis (kulang kulang another 30K) and brake upgrades (disc and pads). computer box, wiring, etc. etc.
hinde naman sha ganun kasakit sa ulo kung malaki budget mo, pero 40k? errr... mag-ipon ka pa siguro, or yun nga, bili ka na lang ng bigger car.
November 13th, 2006 02:13 PM #32
November 13th, 2006 04:36 PM #34
November 13th, 2006 04:46 PM #35
matic nga pala yan,right?
since usapang palit makina: ung H22, anu complete specs nun, at anu tranny kalimitang kasama nun? from prelude yun, diba? may nabuhay lang sa isipan ko,e...
kung gagamitin ung stock matic ng recipient car, magkakaprob kaya, particularly sa life ng matic?
November 13th, 2006 06:29 PM #36H22A
The H22A debuted in 1993 for use in the Honda Prelude VTEC as the H22A1. Versions of the H22A would be the Prelude's signature high-performance engine worldwide until the end of Prelude production in 2001. It was also used in the 1994–1997 Honda Accord SiR and 1998–2002 Honda Accord Euro-R in Japan (however different cams and lightweight crank were used in the Euro R H22A).
Specifications
* Bore × Stroke: 87.0 × 90.70 mm
* Displacement: 2157 cc (132 cu. in.)
* Valve Configuration: DOHC, 16 valves, VTEC
* Type: In-line 4 cylinder, aluminum block and head
* Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan)
* Max power: 190–220 hp (142–164 kW)
* Max torque: 156–163 ft·lbf (207–217 Nm)
* Redline: 7500 rpm
* Engine Control System: Honda Systems PGM-FI with port fuel injection
* Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
* Engine Oil Capacity w/ Filter: 5.1 Liters
H22A4
* The H22A4 is the designation of the engine used in the Base and Type-SH 97-01 Honda Prelude.
H23A1
The H23A1 was an enlarged version of the F22B, designed for the North American market version of the 1992–1996 Honda Prelude Si.
Specifications
* Bore × Stroke: 87.0 × 95.0 mm
* Displacement: 2258 cc (138 cu. in.)
* Compression ratio: 9.8:1
* Max power: 160 hp (119 kW)
* Max torque: 156 ft·lbf (207 Nm)
* Redline: 6500 rpm
* Valve Gear: belt-driven dual overhead cams, 4 valves per cylinder
* Engine Oil Capacity w/ Filter: 4.5 LitersLast edited by ssaloon; November 13th, 2006 at 06:32 PM.
November 13th, 2006 06:42 PM #37
5.1L of oil, dami. magkano kaya bentahan nyan dito ngayon? h22a, ha..w/ manual tranny? any idea? san recomended nyu?
November 13th, 2006 08:26 PM #40
Xiaomi E-Car
