Results 1 to 5 of 5
- Nov 2004
- 115
June 29th, 2005 11:56 AM #1hello,
ano ba ang normal RPM kapag naka idle?
kasi ung sakin pag walang aircon one line before mag 1. pag may aircon, halos nasa one na.
parang masyadong mataas ata? pwede ko ba adjust to ng mag isa?
thanks!
- Jun 2005
- 113
June 29th, 2005 12:53 PM #2Idle speed may vary between different engines but the most common speed is around 750 rpm. Load-compensated idle speed, like when the a/c is operated, may be a little higher at around 900 rpm.
Diesels have an idle adjustment knob or screw on the fuel pump/distributor and may have a solenoid activated idle up actuator.
Sorry I'm not intimately familiar with the Pajero engine (4m41?) so I can't give you the exact details.
- Nov 2004
- 115
June 30th, 2005 08:04 AM #3thanks shadetree! i guess i have to bring it to a mechanic first and i'll watch him do it.
the engine is 4D56 btw..
- Jun 2004
- 476
June 30th, 2005 10:35 AM #4Lifted from the 4d56 Workshop Manual
1. Turn A/C and lamps OFF
- Inspect and adjust at no load
2. Warm engine until idle stabilizes
3. Confirm idle speed is at prescribed value
- 750 plus/minus 100 r/min
Hope this helps
Tsikot Member Rank 5
- Nov 2003
- 3,849
June 30th, 2005 12:02 PM #5yeah, 750-800rpm is normal... if umaabot na ng 1k with a/c that's a bit high
Will they risk kaya to have it installed with a traditional 4speed AT? Just like what they did...
Mitsubishi Xforce
