Results 1 to 10 of 26
November 12th, 2005 09:00 AM #1
i drive a honda eg 95 stock ...may prob ako...please ...kasi pag nag automatic ang aircon ko, ang lakas humina ng hatak nya...khet patag...what would cause this and how to cure this? tapos merong malakas na sound coming from i don't know where pag nag-on sha...could it be the compressor? wag naman sana. there's no problem with the temperature naman. malakas at malameeeg naman ang hagin...TIA for the replies!!!
November 12th, 2005 09:42 AM #2Originally Posted by umzzzzz
November 12th, 2005 12:20 PM #3
oo nga pala...forgot to mention ...tnx dynamo...it's coming from under the hood...walang kalampag sa dash...ang sound kasi is parang may extra motor running...how much would it cost kaya kung yung bearing lang ang ppalitan or i-aalign? thanks again!
Toyota is my choice
- Aug 2005
- 2,063
November 12th, 2005 01:39 PM #4prehas tayo pre.. coming under the hood.. suspect nga daw yong bearing ng compressor or pulley daw.. sana makagawa na tayo ng maintenance para mawala na tunog satin.. parang may extra motor nga.. bro bakit mahina na hatak mo kpag nka a/c on?
November 13th, 2005 03:17 PM #5Originally Posted by umzzzzz
i think i have the same problem as you...mga peeps any info regarding this?...any info / suggestions is highly appreciated..
thanks!
November 14th, 2005 12:33 AM #6
ahihihi...may kaparehas pala ako! anyway...are there alternatives to the legendary mario reyes and daknee? mejo malayo kasi ang panggagalingan ko...(rizal)...thanks!!!
November 14th, 2005 09:51 AM #7
AFAIK kasi pag pinalitan ung bearing tangal ung compressor kaya palit na rin ng freon. So kailangan na rin ng charging. Sama nyo na rin ung palinis ng A/c system nyo. Ako kasi dinayo ko pa si Mang mario para lang sa aircon ko nung nagpalit ako ng bearing. Cost me 1500 petot kasama cleaning and some electronic repairs sa a/c.
November 14th, 2005 02:40 PM #8Originally Posted by dynamo1131
pull down compressor (service charge) - 650
inner bearing - 1000
shaft bearing - 200
compressor bearing - 650
freon charging - 450
compressor oil - 100
cleaning - 450
a whopping three fivee dobol o for me!
oh my gooseneck!!! it's the same job as yours dynamo...only at a higher price!!! better get a second opinion k mang danknee...layo kasi ni mang mario sa place ko.
Toyota is my choice
- Aug 2005
- 2,063
November 16th, 2005 07:52 AM #9wow.. nice nman nyo.. dankee and mario pa home service ako sa cebu.. wow nman.. wish ko lng!
November 16th, 2005 03:24 PM #10
baka naman meron din pong mahusay na gumawa ng aircon sa cebu kagaya nina mang danny and mang mario... i'm sure meron din. goodluck on your search... try asking tsikoteers na taga doon... marami naman atang taga cebu sa atin.
high idle RPM at engine start
