Results 1 to 10 of 10
    Feb 2009
    Hi Mga Sir.
    Car is Rav 4 2001 4X4 M/T.
    Parang wala sa timing, pag tinapakan yung gas pedal pa kadyot kadyot ang andar. bagong palit ang fuel filter bagong linis din ang buong throttle body.
    Pinalitan din namin mga spark-plugs at mga ignition coil, air filter.
    Pag naka neutral at tinapakan ang gas pedal ok naman ang andar walang palya or delay. pero pag may load na usually 1st and 2nd gear pa kadyot kadyot na ang andar.
    Ano kaya posible na pwede ko pa pa check. bagong palit din clutch.
    Thank you mga Sir.
    Apr 2008
    If at low rpm only, try to check the engine and transmission supports.
    Sent from my SM-G900I using Tapatalk
    Jul 2013
    You can also try to bring it to a fuel injection specialist...
    Jun 2008
    might need a reset & re-learn mode to thrle ecu.
    Oct 2009
    hi tension wire also check.
    Dec 2016
    sa EFI system yan sir , same problem with my dad's car, pa check nio po sa specialist para sigurado.. ung trusted nio
    Quote Originally Posted by weisshorn View Post
    If hindi engine support, +1 ako dito.
    May 2015
    this happens to me pero naiisip ko lang parati na it's because mali ang timpla ko ng clutch at gas...
Pa kadyot kadyot sa 1st and 2nd gear.
