Results 1 to 7 of 7
    Jan 2013
    Can I use high mileage oil in a new car? Or a car that has 20k kms on the odometer?
    Been looking for MAG1 oil, and yung 5w30 na semi-synth yung packaging is may naka lagay na high mileage. Wala na ko makita na walang high mileage. Pwede ba sa new car or car na mababa pa ang mileage?
    Oct 2013
    Quote Originally Posted by kris_13 View Post
    Yes you can, pero andami oils na pwede pa, bakit yan pa?
    Jan 2009
    I wouldn't do it.
    It is said that high-mileage oils have additives in them that promotes rubber components such as worn seals to expand. If you do that to a relatively new engine, you may end up shortening the life of these seals instead.
    Only use fit-for-purpose oil for your vehicle.
    Meron 5w30 yung Mag1 na hindi high mileage sir.
    5W30 API SM, ACEA C3-08 Full Synthetic Oil
    * Meets or exceeds European standards ACEA A3 Gas; B04-08 Diesel; C3-08 Gas & Diesel with Catalytic Converter; BMW LL-01, MB 229.51/229.31, VW 502 00/505 00
    Common sense. Low mileage car, high mileage oil. Not match.
    oj88 is correct. the oils for high mileage cars have that compounds that make the seals expand. It will make your engine wear out sooner.
    The car is new, why use MAG1 oil? Dami namang ok dyan eh.
    As they say, never scrimp on the oil. Its your car's lifeblood. Mas malaki magagastos mo pag makina mo nasira.
    Jan 2013
    Quote Originally Posted by vvti2.0 View Post
    Mag1 user kasi ako dati yung semi synth na tig 470 sa ACE. As of now puro high mileage lang meron sa ACE.
    Mag switch nalang sako sa Havoline 5w30 semi synth. Salamat sa mga inputs mga paps.
    Mar 2017
    No! You should only start switching to high mileage oil at more than 120,000km
High mileage OIL, New car?
