Results 1 to 10 of 17
- Dec 2007
- 11
December 13th, 2007 11:38 PM #1guys help, palyado engine ko, civic lxi 96 car ko. dati pag ginamit ko un, bigla na lang prang nawawalan ng gasoline, tapos biglang mag o-ok na, tapos one time nung nangyari un, un na, palyado na talaga, bago plugs, malakas ang kuryente, ndi ko lang sure kung tama ang fuel pressure coming out from the injectors.
tsaka need some info about the valve clearance sa intake and exhaust. many thanks
December 14th, 2007 02:25 AM #2
Sounds like clogged fuel line or malfunctioning fuel pump. Replace your fuel filter, mura lang yan. Do this very basic before mechanic tear down your wallet.
Tsikot Member Rank 4
- 2,719
December 14th, 2007 02:52 AM #3if fuel filter replacement don't fix the problem, you can try inspecting the injector terminals ... they can possibly corrode and would malfunction intermittently ... although all injector terminals have some kind of water protection, it is not water tight, and if the engine is subjected to regular washing, water can creep in and start corrosion process
December 14th, 2007 10:22 AM #4
Fuel filter muna bro, then kung wala pa rin fuel pump, then injectors, then fuel lines, from the very least expensive to the most expensive approach.
- Dec 2007
- 11
December 15th, 2007 05:38 PM #5thanks for the info guys, update ko kayo if ok na. or kung ndi pa, pls help ulit.
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 20th, 2007 10:51 PM #6check the throttle... baka madumi lang kaya you think na wala kang fuel...
- Dec 2007
- 11
December 21st, 2007 10:43 AM #7update!
here's what we've done, fuel filter changed, fuel pump checked, throttle body cleaned and intake manifold, injector checked.
pero ganun pa rin mga bro, pano kaya to? basta pag bigla mo sya apak sa gas pedal parang walang gas nginig ang engine tapos bigla ok sa high RPM, pero pag hinay hinay lang ang apak sa gas pedal to rev ok sya. so you'd think o pede naman pala dirve. un ang another problem ko, pag ginamit ko kotse ayaw humatak kc nga parang walang gas tapos me time na ok, delikado sa overtake, kc nga pag bigla apak sa gas pedal e, walang batak. hirap. layo ko e, d2 kami nasugbu, walang masyado mech.
- Dec 2007
- 40
December 21st, 2007 08:36 PM #8BRo, carburetor ba yan?
check mo na lang ang carburetor nya,,, baka kailangan na ng repair kit...
pag nagawa mo na ang tune-up den ganun pa rin, malamang nasa carburetor na ang prob...di nahahabol ng fuel yung pasok ng hangin...
- Dec 2007
- 40
December 21st, 2007 08:39 PM #9sa ngayon... galawin mo lang yung adjustment ng hangin sa carburetor.. sara mo ng konti... magiging ayos na ang pick-up nyan kaso naman manginginig sa idle...
December 22nd, 2007 05:26 AM #10
based sa choices mo... torn between the Avanza and Innova Livina and Fuzion - big NO I'm...
Buying a second hand car for under 300k
