Results 1 to 17 of 17
    Dec 2007
    guys help, palyado engine ko, civic lxi 96 car ko. dati pag ginamit ko un, bigla na lang prang nawawalan ng gasoline, tapos biglang mag o-ok na, tapos one time nung nangyari un, un na, palyado na talaga, bago plugs, malakas ang kuryente, ndi ko lang sure kung tama ang fuel pressure coming out from the injectors.
    tsaka need some info about the valve clearance sa intake and exhaust. many thanks
    May 2007
    Sounds like clogged fuel line or malfunctioning fuel pump. Replace your fuel filter, mura lang yan. Do this very basic before mechanic tear down your wallet.
    if fuel filter replacement don't fix the problem, you can try inspecting the injector terminals ... they can possibly corrode and would malfunction intermittently ... although all injector terminals have some kind of water protection, it is not water tight, and if the engine is subjected to regular washing, water can creep in and start corrosion process
    Fuel filter muna bro, then kung wala pa rin fuel pump, then injectors, then fuel lines, from the very least expensive to the most expensive approach.
    Dec 2007
    thanks for the info guys, update ko kayo if ok na. or kung ndi pa, pls help ulit.
    Nov 2003
    check the throttle... baka madumi lang kaya you think na wala kang fuel...
pa help po (engine prob)
