Results 11 to 12 of 12
September 8th, 2011 01:27 PM #11
THE AUTO SPECIALIST
- Mar 2006
- 607
September 9th, 2011 03:48 AM #12yes we don't need to touch the engine anymore by using this method and it doesn't matter if gas or diesel engines .
i have been using this method 5 years now and its highly accurate ,
through amp probe that comes with the picoscope equipment, it reads the draw from the battery that the tech will be able to analyze the outcome of the test .
indication that the engine is sound is when we get a uniform waveform display .
if one cylinder has no compression we get no waveform at a certain time . less wave form = low compression
if there is a bearing problem or any resistance from the engine , it shows an excessively high draw from the battery .
if you want to learn more about this technology, pls visit picoscope,com /automotive
Xiaomi E-Car
