Originally Posted by
abyssinian13
mga tol patulong naman nagoverheat kagabi yung nissan sentra b13 namin(16-valve 1.3) tumatakbo siya ng maayos no bad sound coming from engine no smoke) naalarm lang ako na lagpas na sa red yung temperature gauge ko kaya tinigil ko at humanap ako ng mekaniko, nalaman ko na may tagas pala yung connector sa hose ng radiator ko at kailangan hinangin. after mahinang tumatakbo na sya ng normal, questi...on ko lang mga pre may nasira kaya sa engine ko? what signs should I look out for? kanina umaga I started the engine(1-click start and did the talsik test(ok naman may tumatalsik na konting oil when revved, which is normal for 16-valve 1.3 engines ng nissan because of the sprockets' close promixity to the hole on top of the engine) no usok from the dipstick and no usok from the tailpipe. Engine purring like a kitten. I drove it a bit and the engine still performs the same way it did before the overheat happened.
