Coolant in the radiator should be the same proportions as the coolant in the reservoir. Check your user manual regarding coolant types & mixture. Most manufacturers recommend 50:50 mix coolant:demineralized water, some 30:70.. Too much coolant may harm your engine internals.
There are also 2 types of coolant EG & PG.. PG is more environ-friendly but wrong proportions and incorrect duty cycles could result to harmful acids in your engine. Some rust inhibitors in the coolant may also destroy your engine seals and rubbers..
