Results 1 to 10 of 22
March 2nd, 2012 10:52 PM #1
Dear fellow tsikoteers, 'am just wondering what's the purpose of the coolant reservoir attached to the radiator? is it a holding container in case coolant overflows from the radiator? or it in case of overheating, the radiator sucks in the reserve coolant from the reservoir? can anyone enlighten me on this? add ko na rin, is it ok to top up pure coolant in case the level in the reservoir goes down? or it should be diluted with distilled water? Pardon for my ignorance, i've been longing to ask this. TIA
March 2nd, 2012 11:11 PM #2
Reservoir..meaning reserve.. so its use is to reserve so that the radiator wont have a problem.
and on the coolant..ala akong alam :P try to read the instruction in your coolant bottle
March 2nd, 2012 11:12 PM #3
kadalasan pag umiinit nag e-expand. imbes na matapon ang coolant pag nag expand dahil sa init (normal) ay maiipon sa reserba. kaya ang max limit ng reserba ay hindi sagad.
pag lamig naman, mag contract, kaya hihigupin ang coolant pabalik sa radiator.
March 3rd, 2012 12:07 AM #4
salamat sa replies, natanong ko kasi ng sobrang trapik dahil sa rally ng IN
C mejo mataas reading ng temperature more than half sa gauge. then pagkaumaga mejo bawas yung reservoir kaya nagdagdag ako purong coolant hanggang sa kalahati (full level). eh naisip ko baka di dapat puro nilagay ko kundi hinaluan ko distilled water. so far balik na naman reading temperature gauge sa 1/4. napansin ko lang mas mainit hood ko kesa nung nakaraan although same distance and traffic condition. baka napraning lang ako. salamat po uli.
March 3rd, 2012 12:47 AM #5
a 100% working cooling system with no leaks and no problems will never need a top up of coolant or water on the reservoir... its a closed loop system, the same amount that's sent to the reservoir will also be the same amount to be sucked in back to the radiator.
if you topped it up, then the coolant or water which was lost during that traffic must have escaped through something...
try to observe if it will happen again.. but just to be sure check the coolant lines and hoses, and check the engine for any signs of coolant marks..
March 4th, 2012 01:10 AM #6
March 4th, 2012 11:17 AM #7
thanks for the inputs, so it is reassuring that topping up with pure coolant is okay. I see that there is no problem with my radiator as the water level is up to the brim, and the color of the coolant in the reservoir never changes. I'd be alarmed if the color turns to rainbow shade, a sign that oil is seeping in the cooling system.
March 4th, 2012 05:22 PM #8
pwede din top up lang ng distilled water absolut o wilkins . since nageevaporate naman yun water di yun coolant
March 5th, 2012 09:16 AM #10
i did not say 100% sealed... its 100% closed loop system... ibig sabihin self regulating unless buksan o tumagas..
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
