Results 1 to 9 of 9
    Sep 2004
    hello question...
    anong ibg sabihin pag kumakatok yng makina?...kahit mataas na yng rpm pag nag-change ng gear kumkatok parin
    - what does this mean?
    - ways to fix?
    - how much gastos?
    carburator pala ang engine....
    TIA!!
    Jun 2005
    -wala sa timing
    -tuneup or DIY
    -mura lang. pang mcdo mo lang
    alternatively,baka wala na sa lapat ang cylinder head etc. this will cost more...pakita mo na lang sa mekaniko na competent
    Sep 2004
    ty sa reply sir pitbullz!!...ok dali at mura lng pala ayusin...
    katok or tope = engine knock = pinging or hammering = predetonation. it sounds like there's a hammer inside the engine, and that's exactly what it does. predetonation acts like a hammer on the pistons, causing major damage to pistons, connecting rod, crankshaft, cylinder head and cylinder liners.
    causes: too low air/fuel ratio, too low fuel octane used, bad ignition timing.
    fix: adjust carb so a/f ratio is not lean, use higher RON fuel, adjust ignition timing. cheap lang yan, cost of a tune up kung need ng adjustment ang carb or ignition timing.
    but the cost of fixing damage from engine knock is high. spell "overhaul", o-v-e-r-h-a-u-l, overhaul. mura pa din? spell "new cylinder head", or how about "change engine"? wag na haba nun hehehehe...
    Sep 2004
    how would you know if overhaul na kelangan?
    Oct 2005
    iba connotation namin ng tatay ko pag kumakatok/kakatok makina... parang mag bogged down yung engine ang dating samin...so, in short
    laki gastos
    May 2005
    Yan din ba yung kapag cold start, malaki ang standard deviation ng fluctuation ng revs per minute pero kapag medyo mainit na nawawala na?
    Quote Originally Posted by aann
    hello question...
    baka may tao sa loob. pagbuksan mo lang. j/k.
    seriously, nasagot na nila lahat....
    Sep 2004
    Quote Originally Posted by happy_gilmore
    onga noh, bat d ko naisip yun?? hehehe
    Thanks for the replies!
what does it mean pag kumakatok yng makina?
