Results 11 to 20 of 20
December 4th, 2009 11:21 PM #11
That one isn't compatible with the 99 Vectra, and no, we don't have that motor here. The closest you can get locally is the Isuzu Gemini engine, but that's ancient, and it won't mount up directly to the Vectra without extensive modification.
And it'll probably run like dirt.
If you want a front-wheel drive layout diesel, you'll have to import it, sadly. The only late model front-drive engine you can get here in diesel that's not CRDI (and you don't want those, they're expensive, and will be extremely difficult to swap without having some expertise) is the 2 liter diesel in the Nissan AD Max, circa 2000.
- Nov 2009
- 7
- Mar 2007
- 153
December 6th, 2009 12:40 AM #13Last time I checked, which was around a few months ago, here are prices of front wheel drive diesels in banawe QC:
Toyota - 2CT - P40K
Mitsubishi - 4D68T - P35K
Nissan - CD20T - P35k
All are turbo. All are from passenger cars. Most come in A/T but cant remember if the prices i quoted include the A/T.
Toyota and mitsubishi have timing belts i believe. Nissan must have a timing gear like their other diesels - not sure but check. The Nissan TD27 has a steel cylinder head for durability - am not sure if CD20T is also steel.
December 6th, 2009 10:10 AM #14
Timing belt, also.
All imports. You'll be reliant on the Banawe importers for spares... or will have to import them yourself. The CD20T will have some similarity with the AD Max engine, which should mean spares should be available, but I don't know what differences (besides the turbo) there are with the engines... most likely the compression is a bit different, but that's not a big problem unless you need a rebuild.
- Jan 2008
- 380
December 6th, 2009 08:26 PM #15Sir gabyulaw, na-try nyo na ba sa FRONTE MOTORS sa Banawe? sila yung bilihan ng Opel parts. Meron din silang mga mekaniko dun.
- Nov 2009
- 7
December 7th, 2009 03:37 PM #16
- Jan 2008
- 380
December 7th, 2009 03:59 PM #17FRONTE MOTOR PARTS:
Tel: 712-0864
712-0919
23-B kabignayan St. Cor. Banawe St, Quezon City.
Mga pangalawang kanto *Right side galing sa E. Rodriguez.
- Nov 2009
- 7
- Mar 2007
- 153
January 29th, 2010 12:11 AM #19Any updates on this project? I am also interested in a vectra with an engine swap lalo na kung diesel. Compatible kaya axles sa jap axles?
- Feb 2007
- 22
June 15th, 2010 11:51 AM #20sir also planning to do an engine swap for my 2000 opel vectra (matic). any updates po? thanks in advance.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
