Results 1 to 7 of 7
Threaded View
- 54,247
May 26th, 2025 12:44 PM #4kasi,
heavier oils tend to result in higher engine oil pressures, to compensate for the looser tolerances "inherent in worn engines".
whether this helps stave off engine failure or not, i do not know. whether it tends to "tighten spaces between loose metal surfaces", i do not know.
but i do know that using heavier oil can tend to "silence" oil pressure gauge warnings... something bayan sellers take advantage of.
some years back,
i read that modern engines have smaller oil passages and tighter tolerances than older engines.
thus, the need for lighter oils, so that they can more easily pass thru these smaller-caliber oil passageways.Last edited by dr. d; May 26th, 2025 at 12:48 PM.
I want to be clear that I'm mainly against just putting in water (deionized, distilled, or tap -...
Coolant...
