D po general or top overhauling yan sir. Parang cleaning lang po. Pero depende po kasi sa laman kung may tama yun moving parts lalo na yun bore and pistons/rings e parang general overhauling na po.I suggest these work should be done kasi po i don't believe in short cuts as they may give more headache in the long run. Baka in a few months lang or even less kumatok na nang diretso yan engine mo sir. Paano kung gamit nyo sa malayong lugar at dun kayo masiraan.
Let your engine be dissasembled para malinis lahat and then you can assess the damage if meron. Kung wala reassembly lang and may peace of mind na kayo. I think d naman nasira yan kasi d nyo naman natakbo nang malayo at d naman huminto pr tumirik e. Baka cleaning lang at check mga sensors. Bale overhauling gasket,pang change oil lang siguro bibilhin nyo at yun labor nang mechanic. Since nababa nyo na rin baka yun timing belt or water pump pa check nyo na din. After that you're good to go na po.
