Results 1 to 5 of 5
November 11th, 2010 11:30 PM #1
Good day to all Tsikoters
i would like to ask if there's any harmful effects to my engine if i let disconnected the oil pressure switch, sira na rin kasi (putol na ung terminal nya actually), and di ko pa pinababaklas, so naka-disconnect lang, ok lang ba yun?
(SANA PO AY MATULUNGAN NYO AKO SA ISSUE NA ITO, MARAMING SALAMAT PO)
Tsikot Member Rank 2
- Sep 2006
- 1,335
November 11th, 2010 11:57 PM #2
November 12th, 2010 07:00 AM #3
hindi ok yan kasi d mo ma monitor and oil pressure na isa sa pinaka critical sa operation ng engine.
- Jul 2010
- 165
November 12th, 2010 08:33 AM #4The oil pressure switch signals the driver if the oil in the engine is low thru the indicator in the panel gauge. So you should have this replaced to get it working
November 12th, 2010 10:47 AM #5
yep, actually nakabili na po ako oil pressure switch nung last week pa, wala pa nga lang ako time ipakabit sa aking trusted mechanic, wala kasi sya ngaun dito sa place namin, well anyway i always check my oil level and ok naman, hopefull i can replace this thing ASAP,
mga sir, thanks po sa input...
Will they risk kaya to have it installed with a traditional 4speed AT? Just like what they did...
Mitsubishi Xforce
