Results 1 to 4 of 4
- Nov 2006
- 45
November 19th, 2012 07:47 PM #1hi guys, may i ask what is the normal oil pressure of a 4k engine type? i just bought and installed an oil pressure gauge on my 4k engine...
thank you
November 19th, 2012 09:24 PM #2
November 19th, 2012 09:44 PM #3
generally, 10 psi (0.7 kg/sq cm) when hot. about 10 psi increase per 1000 rpm engine speed.
- Nov 2006
- 45
November 20th, 2012 08:16 PM #4mga master, maraming salamat... hay ... buti na lng nasa ganitong range pa ang oil pressure ko.. sira na kasi yung luma eh. kaya nung nabili ko wala ako alam kung ano ang normal nito... salamat ulet ng marami...
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
