Results 1 to 4 of 4
- Nov 2008
- 15
March 25th, 2009 05:40 PM #1Mga sir help naman po may one drop of oil po kasi when I left the garage. nung pag jack ko may mga oil marks yung pinag kakabitan nang oilpan and engine including the oil pan screw also sa mga sensors may oil moisture. san po kaya ok ipaayos ito at mga how much po kaya aabot? car is a crv gen 2 never ending car problems
thank you po
March 25th, 2009 07:07 PM #2
if you're not sure wheres the oil coming from, better bring it to speedyfix to free estimate and check up..
HTH
March 25th, 2009 09:07 PM #3
oil pan gasket. mura lang yan.
kaso, may sistema sa paghigpit ng bolts ng oilpan ng honda ha. may sequence ito at may torque settings (higpit), hindi lang basta isasalpak at hihigptan yung mga bolts (if so, singaw nanaman yan 100% guaranteed).
i suggest pa home service mo na lang sa isang honda mechanic. or, bring it to a shop that has a long experience with honda engines at alam ang mga pasikot sikot nyan. WAG mo pagawa sa gas station mechanic or kay mang pidyong na bumabanat mga mga owner type jeep. di nila alam yan sayang lang pera mo na pinambili ng piyesa (oil pan gasket, buy orig here i suggest).
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 10th, 2009 10:19 AM #4common leaks are from the front crank seal more than the oil pan. make sure muna saan galing before doing the work.
Xiaomi E-Car
