Results 1 to 10 of 12
August 5th, 2013 12:27 AM #1
Hi guys my Honda CRV 2.4 is getting near its 40k kilometer mark. Currently I'm using Honda eco-premium 0w20 oil for my K24 engine. I'm planning on using a different oil this time and I wanted to try the Motul 8100 Xcess 5w40. Question is, should I try on explore another oil or should I stick to the Honda oil?
- Jan 2010
- 367
August 5th, 2013 09:45 AM #3From 20 to 40 grade, guess ko lang sir, baka manibago ka dahil mas pigil sigurado ang takbo ng makina mo sa 40 grade... although check mo rin sa manual sir kung pasok sa 5w-40 ung pwedeng oil sa CRV mo.... just my thoughts..... if ever i-try mo, just give us a feedback.....
August 5th, 2013 09:50 AM #4
Is the 0W-20 Honda prescribed for your engine? I'd stick to that if that's the case. If it's not prescribed then go ahead with the 5W-40.
August 5th, 2013 10:04 AM #5
baka mag suffer fuel mileage mo pag 40 viscosity kung 20 recommened ng honda.
August 5th, 2013 12:17 PM #6
Protection or performance? Of course, the relationship between a higher and lower SAE grade is not linear in terms of engine wear, pero between w20 and w40, w20 will give you more power and fuel efficiency at the expense of engine wear protection.
W20 is recommended for new engines.
August 5th, 2013 12:33 PM #8
Check the car manual and see what the vehicle's oil requirements are. I would always follow the manufacturer's recommendation.
How big is the price difference anyway?
August 5th, 2013 05:00 PM #10
i'm a yokohaman. altii, innova, wigo. ordinary driving. no issues.
Finding the Best Tire for You
