Page 1 of 4 1234 LastLast
Results 1 to 20 of 129
    Aug 2003
    hi peeps!
    i've tried googling this many times already, but couldn't find a straight answer...
    Say you got an old school, EURO-2 engine, and you load it up with EURO-4 fuel; will the emissions at the tailpipe be EURO-4 as well?
    Would adding a catalytic converter make it EURO-4?
    tia
    Dec 2009
    Euro 4 emission is different from Euro 4 fuels
    Euro 4 EMISSION basically define the acceptable limits for exhaust emissions of "NEW VEHICLES"
    parameters measured.
    *nitrogen oxides (NOx),
    *total hydrocarbon (THC),
    *non-methane hydrocarbons (NMHC),
    *carbon monoxide (CO) and
    *particulate matter (PM)
    (ways to reduce this substances is through Exhaust gas recirculation/ 3 way catalytic converter/diesel particulate filter/ ECU programming and timing/ injector advancement and most especially fuel formulation)
    “Euro IV FUELS” standard has applied since 2005, which specifies a maximum of 50 ppm of sulfur in diesel fuel for most highway vehicles (also known as ULSD (ultra low sulphur diesel)
    even though you use Euro IV fuels, but your vehicle was not designed or built to meet emission standards you will still be below euro IV emission..
    if your vehicle is Euro IV compliant and you opted to use below Euro IV fuels then your risking/decreasing service life of your engine internals/injectors and your catalytic converter...
    Advanced and modern catalytic converters and diesel particulate filters require fuels and oils which are ultra low sulphur content, low zinc, low ash, that is to prolong their life...
    if im not mistaken the Philippines is euro II.... just look around at all the buses and jeep... makes you wonder how they pass their emission test
    If you have a diesel engine, you might want to fill up sa Unioil stations coz they claim that they have a 50ppm diesel same with seaoil and PTT. Don't know about their petrols...
    Dec 2009
    Oil companies doesn't divulge their formula as to the content of their petrol fuel but mostly its composed of this primary substances
    1. Aromatics-organic compounds based on the benzene ring, a 6-carbon ring with 3 delocalised double bonds, e.g., benzene, toluene, xylene, etc.
    2. Olefines-organic compounds which have double bonds. After combustion, one critical by-product is 1,3-butadiene.
    3. Oxygenates-organic compounds containing oxygen molecules such as methane, ethane or MTBE (methyl-tertiary-butyl ether).
    gasoline are mainly regulated by the lead(now replaced by benzene) and ethanol(organic compounds) they contain together with octane rating
    while diesel are regulated by the number of sulphur and zinc they contain together with cetane rating
    Sulphur, lead, benzene, toluene are all generally not healthy to humans...
    sorry if i have to bring this topic back. is ptt diesel euro 4 also same with unioil? can anyone confirm this?
    Jan 2008
    Quote Originally Posted by matty View Post
    PTT is Euro2. Check their site.
    Available diesels that are Euro3 and up are from Seaoil, Unioil, Flying V (not sure about Eastern Petroleum)
    Feb 2003
    Quote Originally Posted by miko101130 View Post
    Bro, actually they don't keep it secret naman. If you will buy in bulk say 1 tanker/lorry or more than 10K L you could request for a COC certificate of compliance or kinda laboratory analysis certificate, there it details all the test that was done..i.e cloud point, cetane, ash content, lubricity etc. I have a scanned copy of a recent sample from Shell station for its new Diesoline..says there cetane =52
    . I just dont know how to post it.
    Sir, I have read other threads and some of them are using Euro 4 or Euro 3 fuel from SeaOil and UniOil which are imported. If less lubrication, does it mean bad for the engine?
    Bad for the injection pump. But you can use 2t oil as lubrication substitute.
    If you have a Euro 4 or Euro 5 engine like the CRDIs in the market, why would you need 2T? Who said that you need the lubricant if the engine was specifically designed for this kind of fuel? Can anyone show some tech data to substantiate the need for 2T lubricants?
    Quote Originally Posted by Quint View Post
    you can read everything here:
    http://tsikot.com/forums/engine-fuel...il-fuel-79879/
    all questions you posted has been answered already..
    Jan 2008
    sa CRDI engines mas maganda yung Ultra low sulfur... kasi CRDI engine are designed to run on low sulfur na... bad yang ultra low sulfur sa mga conventional diesel engine that needs the added lubricant...
    Jan 2008
    AFAIK, all diesel engine currently in the country are detuned (Kias, Hyundais, BMWs, Benz, Audis etc) from Euro 5, 4 to Euro 2, 3 to just to make sure cars from those manufacturers can run the diesels sold in the market today majority of which are Euro2.
    and AFAIK, rule of adding 2t naman is not based on fuel but the CRDI system, if im correct.
    refer to sir crazy_boy's link
    Jun 2007
    The local refineries are not yet capable of producing Euro-3 and up diesels. I wonder who among them will produce first and communicate it to consumers?
    Feb 2003
    Quote Originally Posted by EuroFD View Post
    I believe among the local refiners, actually only 2 (Petron and Shell) it will be Petron who could first draw the first blood of complying to the Clean Air Act mandate by 2016. I think they already have an ongoing upgrade of their refineries to meet the fuel specifications as mandated by the Clean Air Act..whilst Shell $100-150 million plan is still on the drawing board. But it is confirmed also that they will have an upgrade of their faciltity to meet the 2016 deadline. If am not mistaken the target will be a EURO IV fuel by 2016.
    Shell to spend $150 M for refinery upgrade - The Philippine Star » News » Business
    Oct 2011
    Quote Originally Posted by Jiggs View Post
    That's great news! cleaner fuel for a cleaner air.
    Apr 2013
    eto yung nsa diesel ng ptt ano siya euro 4 or 2 ba?
    PROPERTIES
    LIMITS
    TEST METHOD
    Appearance
    Clear/Bright
    Visual
    Color, ASTM
    1.50 max.
    ASTM D1500
    Density * 15
    o
    C, Kg/L
    0.82 - 0.86 max.
    ASTM D 1298
    Kinematic Viscosity, cSt * 40
    o
    C
    2.0 -4.5
    ASTM D 445
    Water by Distillation, % Volume
    0.05 max.
    ASTM D95
    Water and Sediment, % Volume
    0.10 max.
    ASTM D 2709
    Sediment by Extraction, %mass
    0.01 max.
    ASTM D 473
    Flash Point, PMCC,
    o
    C
    55 min
    ASTM D 93
    Pour Point,
    o
    C
    0 max.
    ASTM D97
    Sulfur, %mass
    0.05 max.
    ASTM D 4294
    Carbon Residue on 10% Distillation, %Mass
    0.10 max
    ASTM D 189
    (Conradson or Micro Carbon Residue)
    ASTM D 4530
    Cetane Index, Calculated
    50 min
    ASTM D 976
    Distillation,
    o
    C
    IBP
    Report
    ASTM D 86
    50% Recovery
    Report
    90% Recovery
    365 max
    Ash, % Weight
    0.01 max.
    ASTM D482
    Lubricity, (HFRR), wear scar dia.
    460 max
    ASTM D 6079
    Feb 2003
    Sulfur, %mass
    0.05 max.
    That's a Euro2 diesel .05% or 500ppm
    Sep 2009
    Quote Originally Posted by Bengbeng View Post
    PROPERTIES LIMITS
    Cetane Index, Calculated 50 min
    Sulfur, %mass 0.05 max
    Ang importanteng tingnan ay cetane index atsaka Sulfur
    Euro 2 Cetane 50 minimum, Sulfur 500 ppm max (0.05%)
    Euro 3 Cetane 52 minimum, Sulfur 300 ppm max (0.03%).
    Euro 4 Cetane 55 minimum, Sulfur 50 ppm max (0.005%)
    Jul 2013
    .05 ppm is Euro 2 only.
    Aug 2009
    Shall filling with unioil euro4 diesel + 2T work with a 4m40 engine, any experience mga sir? Gd pm.
EURO-4 fuel
