Results 1 to 10 of 10
May 31st, 2015 10:00 PM #1
Mga sir ask lang po k kung OK lang na Hindi paganahin oil cooler? Kasi pansin ko pag hinawakan ko oil cooler dinaman umiinit ano po masisira sa engine pag walang oilcooler? Thanks
- Apr 2015
- 140
June 1st, 2015 12:40 PM #4Ano bang nagiging problema pards pag naka-oil cooler ka? Does it affect performance nga enginre?
- Oct 2009
- 2,271
June 1st, 2015 05:07 PM #5oil cooler nga diba...pinapalamig niya ung oil..
ano nga ba mangyayari kapag kumukulo na sa init ang langis ng makina mo..at ano ba ang mga dinadaluyan nito..
crank shap.piston..piston pin bearing..crank bearing..
rocker arm..lahat ng dinadaluyan ng langis maaring maapektuhan kapag sobrang init ng langis mo..
maganda dyan ipaayos mo nalang ang oil cooler.mo..at wag mong tanggalin..may function yan kaya inilagay dyan yan...
- Dec 2013
- 680
June 1st, 2015 05:54 PM #7Pano malalaman kung sira na ang oil cooler na hindi kinakalas yung buong assembly?
June 1st, 2015 06:30 PM #8
Signs of Engine Oil Cooler Failure | eHow
Read on.
http://www.ehow.com/list_7591621_signs-engine-oil-cooler-failure.html
Read on.
- Dec 2013
- 680
June 1st, 2015 07:18 PM #9Thanks! Except na tumutulo yung oil sa area ng cooler, wala naman yung ibang symptoms. Performance la naman masyadong maexpect sa 4ja1. Mabagal talaga. Normal din na mausok pero puti naman. Vibration maalog pero normal naman. Radiator ok naman and im guessing higher temp is because of the summer heat. Baka gasket lang.
Xiaomi E-Car
