Results 1 to 10 of 10
    Feb 2012
    Mga sir ask lang po k kung OK lang na Hindi paganahin oil cooler? Kasi pansin ko pag hinawakan ko oil cooler dinaman umiinit ano po masisira sa engine pag walang oilcooler? Thanks
    Feb 2012
    BTW Hyundai grace po van ko d4bx engine clone daw ng mitsub4d56
    Feb 2012
    Up ko lang po
    Apr 2015
    Ano bang nagiging problema pards pag naka-oil cooler ka? Does it affect performance nga enginre?
    Oct 2009
    Quote Originally Posted by sotel View Post
    oil cooler nga diba...pinapalamig niya ung oil..
    ano nga ba mangyayari kapag kumukulo na sa init ang langis ng makina mo..at ano ba ang mga dinadaluyan nito..
    crank shap.piston..piston pin bearing..crank bearing..
    rocker arm..lahat ng dinadaluyan ng langis maaring maapektuhan kapag sobrang init ng langis mo..
    maganda dyan ipaayos mo nalang ang oil cooler.mo..at wag mong tanggalin..may function yan kaya inilagay dyan yan...
    Feb 2009
    CrankSHAFT
    Dec 2013
    Pano malalaman kung sira na ang oil cooler na hindi kinakalas yung buong assembly?
    Quote Originally Posted by n_spinner06 View Post
    Signs of Engine Oil Cooler Failure | eHow
    Read on.
    http://www.ehow.com/list_7591621_signs-engine-oil-cooler-failure.html
    Read on.
    Dec 2013
    Read on.
    Read on.
    Thanks! Except na tumutulo yung oil sa area ng cooler, wala naman yung ibang symptoms. Performance la naman masyadong maexpect sa 4ja1. Mabagal talaga. Normal din na mausok pero puti naman. Vibration maalog pero normal naman. Radiator ok naman and im guessing higher temp is because of the summer heat. Baka gasket lang.
    Feb 2012
    Read on.
    Read on.
    Parang kulang yung paliwanag dun sir hehe
Oil cooler
