Results 21 to 30 of 30
October 14th, 2004 12:09 PM #21
Hi Doc Diesel, Thanks, very informative reference. I'm confident that my turbo charger is still working but how efficient is another thing. I have to DIY the process as mentioned on your guidelines.
The OEM intercooler sensor priced at 1050 at El Dorado's, I might replaced this on weekend to prevent intercooler fan motor from burning.
By the way, what is this starting fluid used to check leakages between turbocharger and air cleaner?
October 14th, 2004 07:11 PM #22
is there oil before the turbo and after the breather that goes into the intake? if none maybe the turbo is leaking oil if there is normal lang yon, accumulated lang siguro after how many years. the important thing is that it does not consume oil.
- 3,754
October 14th, 2004 08:40 PM #23Pasingit.. Since you guys talking about TURBO.. what could be the problem for this.. Nag babaga na yung turbo ko in a long run..lalo na sa high speed
October 15th, 2004 11:05 AM #24
Nightrock, baka may bara sa cooling system nung turbo. Check mo yung hoses connected to it. As far as i can recall meron coolant na dumadaan sa turbo.
Doc D, sir the oil I found in the turbo came from the cylinder head. I noticed some oil coming from the EGR hose going to the turbo. Pero sir nabenta ko na ho itong pajero na ito heheh.
Field Master, as long as the turbo is properly lubed and wala namang deformities sa fins, it should work fine
01 EX Ody
- 437
October 15th, 2004 11:45 AM #25nightrock,
may instances na magbabaga talaga yung turbo since it generates so much heat na it looks like red hot coal that you can cook on. just make sure lubrication is always there.
wala rin coolant that goes into the turbo.....
Doc D.
October 15th, 2004 11:53 AM #26
Well, I have to find it out tomorrow kung:
1) Saan galing ang langis - meron kasi akong nakita sa black flexible hose connected to turbo going to intercooler. Eto ba yun breather?
2) Fin damage - will inspect this after removing the mentioned flexible hose.
3) Coolant - Confirm ko kung meron nga.
Tapos gagawan natin ng diagram para madaling maintindihan ng ibang tsikoter (4m40 makina ko).
October 15th, 2004 11:56 AM #27
Oops, my bad I just noticed a tube in the rear end of the 4D56TDIC going to the turbo which has coolant in it. Forgot the specifics already its been a long time.
October 15th, 2004 11:59 AM #28
sir docdiesel, san yung turbo troubleshooting guide nyo? dito ba sa tsikot>
October 15th, 2004 03:13 PM #29
My hose nga with coolant that goes in the area of the turbo. Have to check pa if it indeed cools the turbo.
Nagkaproblem ako sa hose na yun dati, eh.
01 EX Ody
- 437
October 16th, 2004 08:11 AM #30Originally posted by niwde11
Doc D.
