Results 1 to 14 of 14
    Jun 2005
    hello to everybody!mga friends ask ko lang which is the best fuel for my honda civic(velocity,vortex,blaze ,etc.)alam ko naman maraming may experience dito .i'm currently using petron unleaded kaya lang parang mahinang humatak.thanks a lot and more power!!!!!
    try mo shell unleaded. as much as possible, try to use the lowest octane fuel muna.
    ako kasi, i've tried total unleaded and petron unleaded, parang kapos-kapos din. i'm using shell unleaded now.
    Jun 2005
    slamat pero diba mas higher octane rating mas malakas humatak?
    not necessarily. kung turbo engine mo, ramdam. pero kung stock lang. hinde.
    kailangan lang ng high octane gasoline kung high compression ang engine mo (tulad nung sa cr-v & rav4).
    check mo na lang yung nasa manual mo.
    petron try mo.. hehehe.. pero dati shell unleaded ako.. ngayon lang nun lumabas un extra.. pero nagkaproblema plugs ko.. pero siguro just in time lang
  7. #7
    Pag walang engine knock or tope, stick to the lowest RON rating.
    Quote Originally Posted by mazdamazda
    Unleaded gamit ni erpats, ok naman so far... walang engine knock
    Quote Originally Posted by ILuvDetailing
    That is because newer engines WILL compensate for the lower octane rating by adjusting / retarding the ignition timing. The downside is that it will lead to poor engine performance & fuel economy.
  9. #9
    I see. Thanks for the info mazda2.
    Jun 2005
    do you think if i use a fuel with higher octane rating like velocity magiimprove kaya performance and fuel consumption ko?
    Quote Originally Posted by liwanag
    No. It is just a waste of money to do that.
    Though you can use high-octane fuel once in a while to clean out your fuel system.
  12. #12
    Have some questions:
    Hows does it clean the fuel system?
    Kailangan bang hataw mode?
    Does using a higher octane fuel than recommended foul the plugs quicker than usual?
    the additives blended in with premium gasoline will help clean the injectors / carb.
    to really clean carbon deposits do the following (even without the use of premium gasoline):
    1. while in 2nd gear, accelerate till you reach the redline
    2. release throttle
    3. repeat for 2-3 times
    i don't think so.
best fuel for 2002 honda civic vtis at
