Results 11 to 14 of 14
June 15th, 2005 05:03 PM #11Originally Posted by liwanag
Though you can use high-octane fuel once in a while to clean out your fuel system.
June 15th, 2005 05:09 PM #12Originally Posted by mazdamazda
Hows does it clean the fuel system?
Kailangan bang hataw mode?
Does using a higher octane fuel than recommended foul the plugs quicker than usual?
June 15th, 2005 05:23 PM #13Originally Posted by ILuvDetailing
to really clean carbon deposits do the following (even without the use of premium gasoline):
1. while in 2nd gear, accelerate till you reach the redline
2. release throttle
3. repeat for 2-3 times
high idle RPM at engine start
