Results 1 to 10 of 14
- Apr 2014
- 231
September 26th, 2017 02:34 PM #1Previously using Mobil Super 1000 15w40 and after that, Honda Vtec Lev 10w30 which are all Mineral Oil ...
Engine was ok and noise is normal ..
Change to Mobil Super 2000 10w40 Semi-Synthetic Oil .. Now the engine is very audible .. You can the valve tappets ticking ...
Is it a normal noise of semi synthetic engine ?? Will it damage my engine in the long run ?? Or is it only Mobil because some say Caltex Havoline Semi Synthetic offers a silent engine ...
Should I go back to Mineral Oil ???
Car is Corolla .. Engine is 1.6 4afe ...
September 26th, 2017 06:19 PM #3
not oil related imo. time for tappet adjustment..
- Apr 2014
- 231
September 26th, 2017 09:36 PM #4
- Apr 2014
- 231
September 26th, 2017 09:54 PM #6Hindi naman knocking noise ang naririnig ko sir ... same fuel as before pa rin ginagamit ko .. mas audible lang ang noise ng valve tappets ngayon na nag semi-synth oil ako, dati sa mineral oil hindi naman ganito ka ingay ang tappets .. lalo nag pag operating temp na, tahimik na tahimik na ... pero ngayon sa semi synthetic oil, kahit operating temp na, dinig na dinig mo pa rin ang valve tappets noise kahit naka sarado ang hood ..
- Apr 2014
- 231
September 26th, 2017 09:56 PM #7
September 26th, 2017 10:00 PM #8
Synthetic oil has good detergent capabilities. Most probably, it loosened the "mineral" build-up on your valve train, hence the noise.
- Feb 2014
- 2,696
September 26th, 2017 10:53 PM #9don't fix if it ain't broken LOL i mean why change to fully synthetic anyway?
funny i just saw my 90's corolla driving past earlier tonight, probably by it's 3rd owner. it's probably as old as your car. i never used fully synthetic on it
btw when was the last time you checked the valve clearances? paano ba adjustment ng 4afe? shim based?
- Apr 2014
- 231
September 26th, 2017 11:08 PM #10
I registered my car earlier before it expires (4mos before the expiry). Better to do it early po....
transfer of ownership / registration cost
