Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
    Sep 2008
    Hello mga bossing...
    curious lang po ako if may tsikotters ba na gumamit ng coconut oil as engine lubricant or additive?
    Na encounter ko po itong site. Coconut Oil -
    "Coconut oil has been tested for use as an engine lubricant; the producer claims the oil reduces fuel consumption, smoke emissions and allows the engine to run at a cooler temperature. As an engine lubricant, coconut oil performed better than mineral based engine oil in terms of lubricity, smoke point, flash point and resistance to oxidation. It also dissolves carbon deposits left in the engine for using mineral based engine oils that burn easily during the combustion process. It is not the fuel that leaves more carbon deposits but mineral based lubricants. It is found out that engines treated with coconut oil as oil additive produce no more or less smoke than without coconut oil.Engine maintenance would be lesser as compaired to using mineral based engine lubricants. Coconut oil is also cheaper and last longer even more than a year of use in your daily driven vehicle. In Indonesia, Malaysia and the Philippines, more and more vehicle owners shifted to using coconut oil or palm oil as engine lubricant. Not only that is it cheaper and abundant, it is far superior than the expensive engine lubricant that is available on the market today."
    ito pa;
    KDI TEST & REVIEW - USING COOKING OIL AS ENGINE OIL
    Comments naman jan mga masters at sama nga naka subok na nito
    more and more vehicle owners in the Philippines?!? ... Someone might be blowing wind out of his holes on this claim.
    Although it is true that more and more vehicles are using coconut oil but as fuel (diesel fuel substitute) either as-is or when coconut oil is converted to bio-diesel. I have never heard of anyone using coconut oil as engine lubricant. For one, it is too thin to provide adequate protection against metal to metal friction.
    One major problem is that coconut oil will gel at around 10C degrees. Imagine what damage that will result in your engine.
    Sep 2008
    salamat po sa comment boss.... iwan ko ba anong naging basihan ng writer na yun.
    pero siguro naman as tropical country except sa Baguio area hindi issue ang gelling point at 10c degrees
    Jul 2015
    Coconut oil ang gamit ko for almost 4 months now at sa experience ko lalong gumanda ang hatak at takbo ng car ko plus malaki ang naging savings ko sa fuel, nag try lang ako and very satisfied ako
    Quote Originally Posted by Palongkilang View Post
    ito pa;
    Jul 2015
    May mga car owner na sa baguio na ang gamit ay coconut oil sa engine nila,naka bawas ng malaki sa usok ng sasakyan nila, i suggest na i try po ninyo.
    Aug 2012
    Quote Originally Posted by Biorev View Post
    Anong car model ang ginamitan mo ng coconut oil? Picture naman dyan ng car at oil na ginamit mo.
    Did you use the coconut oil as engine lubricant in its natural form? Because coconut oil will never stay in liquid form in Baguio temperatures. Ang pag benta nga ng cooking oil sa Baguio is in cake form na. ini-slice sya.
    Signature
    Jan 2012
    baby oil naman ang gamit ko LOOOOOL
    Nov 2014
    ^ Ako rin, pero pinapatakan ko ng konting lavender essential oil para relaxing yung fumes. Plus konting tea tree oil para sa antiseptic properties. Optional din daw ang peppermint kung gusto mo yung medyo nakakagising habang nagdadrive
    Langis ng niyog?
    Ano kaya amoy ng usok nyan? Amoy latik......
Coconut Oil as Engine Lubricant or Additive to engine oil
