Page 1 of 2 12 LastLast
Results 1 to 20 of 32
    Sep 2008
    Hello mga bossing...
    curious lang po ako if may tsikotters ba na gumamit ng coconut oil as engine lubricant or additive?
    Na encounter ko po itong site. Coconut Oil -
    "Coconut oil has been tested for use as an engine lubricant; the producer claims the oil reduces fuel consumption, smoke emissions and allows the engine to run at a cooler temperature. As an engine lubricant, coconut oil performed better than mineral based engine oil in terms of lubricity, smoke point, flash point and resistance to oxidation. It also dissolves carbon deposits left in the engine for using mineral based engine oils that burn easily during the combustion process. It is not the fuel that leaves more carbon deposits but mineral based lubricants. It is found out that engines treated with coconut oil as oil additive produce no more or less smoke than without coconut oil.Engine maintenance would be lesser as compaired to using mineral based engine lubricants. Coconut oil is also cheaper and last longer even more than a year of use in your daily driven vehicle. In Indonesia, Malaysia and the Philippines, more and more vehicle owners shifted to using coconut oil or palm oil as engine lubricant. Not only that is it cheaper and abundant, it is far superior than the expensive engine lubricant that is available on the market today."
    ito pa;
    KDI TEST & REVIEW - USING COOKING OIL AS ENGINE OIL
    Comments naman jan mga masters at sama nga naka subok na nito
    more and more vehicle owners in the Philippines?!? ... Someone might be blowing wind out of his holes on this claim.
    Although it is true that more and more vehicles are using coconut oil but as fuel (diesel fuel substitute) either as-is or when coconut oil is converted to bio-diesel. I have never heard of anyone using coconut oil as engine lubricant. For one, it is too thin to provide adequate protection against metal to metal friction.
    One major problem is that coconut oil will gel at around 10C degrees. Imagine what damage that will result in your engine.
    Sep 2008
    salamat po sa comment boss.... iwan ko ba anong naging basihan ng writer na yun.
    pero siguro naman as tropical country except sa Baguio area hindi issue ang gelling point at 10c degrees
    Jul 2015
    May mga car owner na sa baguio na ang gamit ay coconut oil sa engine nila,naka bawas ng malaki sa usok ng sasakyan nila, i suggest na i try po ninyo.
    Did you use the coconut oil as engine lubricant in its natural form? Because coconut oil will never stay in liquid form in Baguio temperatures. Ang pag benta nga ng cooking oil sa Baguio is in cake form na. ini-slice sya.
    Signature
    Jan 2012
    baby oil naman ang gamit ko LOOOOOL
    Apr 2012
    Quote Originally Posted by Biorev View Post
    meron na ba gumagamit sa baguio nyahaha! alam mo ba hitsura ng mantika dun bro pwede pamukpok sa ulo mantika dun maganda pala yan kung nasa baguio na, pwede ka na bumili ng langis ng sasakyan nakabalot sa dyaryo nyahahah! o baka naman sinasabi mo yung brand ng mantika na baguio cooking oil gawa sa san juan hehehe..pwede rin yan brad, karkagan mo makina mo tapos punta ka ng baguio. then stay ka ng overnight
    dami mo naman magamit na lugar Baguio pa eh unang una wala naman niyogan diyan. dapat mga bandang Baler Aurora ang gamitin mong example na lugar kasi malawak niyugan diyan. kahit araw-araw ka mag change oil pwede
    From the article cited:
    - White vapour comes out from exhaust which means more efficient combustion
    OMG!
    OMG!
    Jul 2015
    Coconut oil ang gamit ko for almost 4 months now at sa experience ko lalong gumanda ang hatak at takbo ng car ko plus malaki ang naging savings ko sa fuel, nag try lang ako and very satisfied ako
    Quote Originally Posted by Palongkilang View Post
    ito pa;
    Aug 2012
    Anong car model ang ginamitan mo ng coconut oil? Picture naman dyan ng car at oil na ginamit mo.
    Jul 2015
    Quote Originally Posted by red_one View Post
    Toyota innova 2011 model /manual yung sa brother ko montero sports 2013 model mas pumino ang ingay ng sasakyan
    May 2010
    Wrong forum to post these claims in, especially with a newly registered user account. Hindi bobotante mga tao dito sir na nadadala sa mga testimonyang ganyan. Marunong kaming pumili ng mga kandidatong subok na at ayaw namin sa trapo na kahit ano ipapangako.
    "Vote wisely"
    Langis ng niyog?
    Ano kaya amoy ng usok nyan? Amoy latik......
    Mar 2012
    Pwede kaya yung pinagprituhan sa mga fastfood? Para langhap-sarap ang smoke emission
    Jul 2013
    Quote Originally Posted by maki mi View Post
    Pwde as fuel pero matinding filtering ang kailangan mo. Mas okay yan kung sa old school diesel engine kesa sa mga crdi/d4d para hindi sensistive sa maduming diesel.
    hindi pwede yan baka sabihin nila umutot si jollibee
    Jan 2011
    just curious lang po sir. anong ibig sabihin mo sa coconut oil? coconut oil ba, yong coconut milk at pinakulo hanggang sa pure oil na siya or virgin coconut oil? additive ba siya or pure coconut ang ginamit mo as engine oil? if additive, gaano karami? last question ko po, diba mabilis mag degrade ang coconut oil considering the extreme heat sa makina natin?
    Mas important na tanong, ano ba una ilalagay, sibuyas o bawang?
    Aug 2012
    Dati akong akong gumagamit ng tinatawag nilang GTO, pero nong nalaman kong xtracted pala sya from plants, sabi ko sa sarili ko, "eh di pwede rin ung coconut oil? yong coconut milk at pinakulo hanggang sa pure oil". So I searched from the net about coconut oil as an additive or engine oil mismo, nasearch ko na pwede pala gamitin. I was reading it mga May 2014, then I started using it (I tried the first time with my eye closed at di ko alam kung anong harm na idudulot sa engine ng L300 ko), I put 250ml for the first try as an additive and not a change oil kasi I was afraid to use it as an engine oil mismo. You know what? ang effect ay agad agad, gumanda hatak ng L300 ko. Mula that time (may 2014), I put 250ml every 3mos and last April, 1.25 smoke test ng L300 ko. Last year eh di pumasa L300 ko, sabi ng smoke test center eh pagawa ko daw injection pump ko, I just ignore it kasi one click start naman siya. I am not making a fake story, totoo to mga bros. D2 pala ako sa Benguet at ang ginagamit kong engine oil is Caltex DELO gold.
    Eto pala L300 ko...
    Pamalit sa diesel, oo. As lube, hindi. Me episode sa Top Gear UK na ginagawa yan
Coconut Oil as Engine Lubricant or Additive to engine oil
