Results 1 to 20 of 20
    Apr 2006
    just an update... my supplier replaced the carb i bought and i installed this last monday... engine ran smoother... but hard cold starting again... actually worse... left it with my mechanic and he noted that it seems the carb injects too small an amount of fuel... need to pump the accelerator pedal several times for it to start... what can i do to remedy the situation? help
    May 2008
    priming the 2E carb is a must before starting. no electronic controls just an accelerator cable. E10 only made it worse. also the fuel pump is mechanical and the engine has to be running for gasoline to flow to the carb. different from the gli that is fuel injected with an electric fuel pump that starts to pump the moment you turn the ignition on. before the fuel injected systems, electric fuel pumps provided better pressure thru the fuel lines for twin carb set ups.
    Apr 2006
    does that mean that even if i put in a new 2e carb or have my original 2e carb, i'll still have the same problem? maybe not just to the same degree? (re: less priming?)
    May 2008
    yup, will still need to be primed. you can try depressing the gas pedal about halfway when you start up. let the cranking motion of the engine cause the fuel pump to flow the gas into the carb. personally, i prefer priming. i have seen to many engines revved unnecessarily when started with the gas pedal. its a finesse move that takes getting used too. not the best way to start up a cold engine. if you have ever tried starting a flooded engine, its something similar.
    Apr 2006
    thanks... i have tried the 'depressed' accelerator start... difficult to master...
need help hard starting corolla big body 2e
