Results 1 to 10 of 10
November 20th, 2008 10:51 AM #1
Greetings tsikoteers and auto-gurus
I urgently need your expert advice or inputs regarding my current predicament . This problem only started this week, but seems to have gotten worse since yesterday and this morning. The car seems to "choke" or "gag" pag driving at slow speeds, mga 20 to 30kph whether in low gear or at 3rd, especially during traffic. When i say choking (kasi ala ko maisip na better term ) what happens is parang tumatadyak bigla ng sunod-sunod ung auto, this morning mejo malala ung tadyak halos tumapon ung mga CDs and shades ko sa dashboard, afterwhich namatay ung auto. Another thing i noticed is everytime pumitik ung thermostat ng aricon, either hihina ung hatak ng auto or the other way around: lalakas naman. I have no idea if this is related to the choking thing, pero mas madalas talaga ngayon, when in fact i never had this problem prior to a few days ago. And pag nag start ung choking, the only way i can stop the jerking (which would lead to the car dying, no pun intended ) is the hold down on the clutch and then slowly release ulet para mag rev ng konti, kaya lang dehins pwede ito lagi pag traffic dahil slow speeds lang tayo dun.
Ang haba nito ah, anyways, would greatly appreciate any inputs, similar experiences and expert advise on what could be causing this and how to resolve or para madali din i-explain sa mech if ever.
Thanks in advance, peeps.
November 20th, 2008 11:31 AM #2
Long enought, but forget to mention what kind of vehicle you have. Like makers of the car, model and year. We need all this info when asking.
I tried to understand your explaination the best I can and there's one thing came out in my mind. Again, this is only my 2 cents.
You can check the TCC solenoid is located in the transmission on the valve body. To verify that this is causing your problem, disconnect the four wire plug that plugs into the side of the transmission and drive the car. If your problem is cured, replace the solenoid.
Update us.
November 20th, 2008 01:52 PM #3
oops! nga pala sorry for that, i'm using a corolla '89, 12valve m/t 4speed.
noted on the solenoid. will include this in my checklist. thanks for that one
November 20th, 2008 04:14 PM #5
THE AUTO SPECIALIST
- Mar 2006
- 607
November 21st, 2008 09:50 AM #6ipa road test mo sa mekanik mo para malaman kung tranny or engine ang cause
December 3rd, 2008 04:19 PM #7
yup, mechanic checked the car and did a test drive. we noticed that the choking occurs only when shifting from 1st to 2nd gear, hence the slow speeds. What he did was replace a bearing for the fan belt, adjust the fan belt and replace the engine support(??) two of them. I have been driving the car for a few days now, and even though mejo nabawasan ung nginig, it's still there. We are still trying to find out what else could be causing this. Clutch lining na kaya? Pero it only happens on one gear shift 1st to 2nd. Transmission support? Hayyy
THE AUTO SPECIALIST
- Mar 2006
- 607
December 3rd, 2008 11:08 PM #9Check fuel pump volume
check the acceleration pump( inside the carb , that's the one giving power during accel)
if it's not giving enough spray , time for a carb overhaul
Xiaomi E-Car
