Results 1 to 6 of 6
- Mar 2013
- 139
October 2nd, 2013 05:07 PM #1Nag adjust po ako ng valve diy lang sa 13t sinunod ko yung sa 3t kasi pareho daw yung specs nun from what ive read on some forums.
.20mm intake
.33mm exhaust
tdc on 1st cyl for first set of valves then rotated 360* to adjust 2nd set
tama po ba yung specs ng valve lash ko?
done on normal operating temp according sa manual.. ang problema ngayon may detonation madalas sa 2nd gear/3rd kapag aarangkada.
nag jejerk tapos walang power tpos may parang pumuputok-putok sa passenger side and na notice ko kapag medyo mainit na makina. kapag malamig ok sya yung kaka andar mo lang
hinala ko sa unleaded kasi sa pagtipid ung mga low class lang kinakarga ko. di ko pa nasubukan na premium/high octane. pero dati unleaded naman ako walang ganun, apektado siguro ng pag-adjust
eto pa, may play po ba yung pushrod kasi inalog alog ko umaalog sya tapos may parang tunog na slamming metals need na po ba for overhaul?
tnx in advance!
- 54,290
October 4th, 2013 01:15 AM #3err... are you sure of your specifications?
and er... are you confident that you did the valves in the correct order? i mean, it's not 1-2-3-4. 1-3-4-2 or something like that is the usual... (i'm a little embarrassed to have asked this question, but ... i have seen it happen once in a while.. naninigurado lang.)
and your last statement is confusing to me... pls try again..Last edited by dr. d; October 4th, 2013 at 01:29 AM.
- Mar 2013
- 139
October 4th, 2013 09:55 AM #4confident naman po mga bossing and following the manual for the valve adjustment order
first set is 1-2 for intake 5-7 for exhaust (1st piston TDC)
2nd set is 3-4 intake; 6-8 exhaust (rotated 360*)
and the engine is 20+ year old na siguro
the last one is for the pushrod "play" when you shake it.. i think the clearance is wider than specs already
- Mar 2013
- 139
October 4th, 2013 10:59 PM #5wala na yung detonation nag adjust lang ng dist. timing... pansin ko yung hatak and fuel consumption mas ok
- 54,290
October 4th, 2013 11:18 PM #6it is easy to adjust ignition timing by just rotating the distributor, but you have to know exactly what your specs are, and that you are adjusting them accordingly.
read: you need a timing light. adjusting the timing without it is just an emergency procedure, to get your car to the shop that has one.
the pushrod side-to-side movement? i am confident some movement is allowed, and i am not aware if there is a table of allowable lateral tolerance...
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
