Results 1 to 10 of 12
December 10th, 2008 10:32 PM #1
guys pinabalik ko ung stock headers ko tpos biglang may nag spark sa bandang headers tpos dinisconnect nila ung battery terminal after the spark happend tpos nung pag star ko walng aircon, power windows batter check naka ilaw blower di na ikot at hindi ko na alam kung anu pa nawala.. anu ang naging problema nito severe p ba? dinala ko sa casa ung car ma honor kaya ung warranty nito? mga mag kanu kaya to fuse kaya lang ang sira? haay...
PS : ayoko na galawin ang oto naawa na ko kaka mods ko nasira...
Tsikot Member Rank 4
- 2,719
December 11th, 2008 12:16 AM #2yung ganyang aksidente ang dahilan kung bakit dapat idiskonekta ang battery tuwing meron gagawin sa engine bay
sana nga, fuse lang nadale ... umandar naman engine, so most likely intact ang electronics nya
battery check means your charging system have a problem ... baka nadamay ang electronic regulator sa loob ng alternator ... or fuse lang din (sana)
good luck po
December 11th, 2008 12:28 AM #3
Kung may warranty ang kotse mo malamang void yan dahil modification ang ginawa ninyo. Now, the only way to get away with this is to bring back all the original na tinangal ninyo then bring your car to Casa.
Your mechanic should known better to disconnect the battery cable whenever the working on your engine. A 30 seconds job now its a full blown headache. Check all the fuses, relay including burn wire cause by spark and check all the continuity.
Hope for the best and goodluck.
December 11th, 2008 01:55 AM #4
Salamat po!.. tinanung ako sa casa kung anu anu ginwa ko sa kotse sabi ko nag kabit lang ako ng muffler at bolt on sya un lang... tpos un nga iwan ko daw ung kotse so iniwan ko, tatawag nlng daw sila,
yes binalik ko lahat ng stock sa car...
sana nga fuse lang and sana magawa na kung anu man ung sira at sana kung may babayaran ako wag sobrang mahal.. haay...
December 11th, 2008 10:28 AM #5
malamang nadale ibang fuse yng aircon mo ba me hangin pero walang lamig? me isa ka din gastos dyan yung sa alternator mo malamang nadamay
December 11th, 2008 12:06 PM #6
check alternator especially yung brush nya. nangyari na yan sa kin na umilaw ang battery check, brush ng alternator pudpod na. also check regulator, baka nadale...
December 11th, 2008 01:05 PM #7
o kaya sir check din yung mga main of all fuse sa tabi ata ng battery naka locate yun kundi ako nagkakamali...pwede ayun na ang sirain nya.
December 11th, 2008 03:23 PM #8
Haay... ayoko na kalikutin ung car ko pag naayos ba nila un good as new na po ba un?
December 12th, 2008 10:07 PM #10
Casa maintain po tlga balak ko 3 yrs warranty po kasi sya.. sana ok na haay...
di ko pa alaam kung kelan ko makukuha.. paanu ko malaman kung working na ang alternator ko po at mga electricals one na bigay na sakin ung car ko?
Well looks like they're gonna make it easier na to transfer ownership. Timely since I need to...
transfer of ownership / registration cost
