Results 1 to 3 of 3
- Jun 2009
- 12
June 30th, 2009 02:33 PM #1tumirik kasi ako nung isang araw then sabe ng mekaniko palinis ko daw ang distributor kasi daw nagaasin?may ginawa lang sya then afterwards umandar naman kaso sabe nya palinis ko na daw.and 1 more thing pagnagon ako ng headlights nagflufluctuate ang rpm ko baket kaya?san ba pwede pacheck ng distributor sa electrical shops ba?
June 30th, 2009 06:24 PM #2
Calcium deposits ata yung dun sa loob ng distributor cap. Yung kulay puti. Before, sa 1980 Galant Sigma ko, kinikiskis ko lang yung contacts using a knife, tapos spray with WD-40.
Kung nagfa-fluctuate yung rpm pag in-on ang headlights, malamang sa alternator ang tama. Kulang ang load.
July 4th, 2009 04:31 PM #3
arvin,
the white powdery substance found inside your distributor cap is aluminum oxide. the high voltage inside the cap and the moisture in the air concoct this powder. if your distributor cap had steel or copper contacts inside, the oxides will look differen; if it was copper contacts, it would be greenish. this means that the moisture is permeating inside the disrtributor cap or the cap has a vent. most oem distributors or distributor cap have a neoprene gasket for this purpose. that subtance you are talking about is the same substance if you have aluminum cylinder head and your engine is using nothing but water for coolant. you will see this at the coolant recovery bottle as a gel but when it dries up, it will be powdery aluminum hydroxide
jick
Xiaomi E-Car
